74 Honda CB550 Four - Compression Test
mcenz25
Stop, listen, and then listen again.
This will be my first attempt at testing the compression on this (any) engine. I see external signs of oil on cylinders 1 & 2, while 3 and 4 are dry. The carbs are off so I'm assuming the there isn't anything else to do but connect the gauges and crank the starter. Here are the results: C1 = 180 lbs, C2 = 190 lbs, C3 = 165 lbs, and C4 = 155 lbs. Everything I read talks about a variance of 10 lbs across the entire set is what I should expect. Cylinders 1 & 2 seem to be above the normal compression range for the cb550. Cylinders 3 & 4 are more than 10 lbs lower than the first two but closer to normal(?).
Here is where the questions begin. Which pressure is more desirable? What is the reason for the (abnormal?) higher readings?
I also noticed the spark plug threads for cylinder 1 are 'chewed-up'. The other three cylinders would accept the gauge and spark plug under hand turning. Cylinder 1 is very tight as far as the threads go, the gauge goes in but hard, and the spark plug will not hand crank...you're under ratchet power from start too finish. I'm guessing someone over tightened the spark plug sometime in the past and starting pulling the threads.
I will try adding oil to the low cylinders tomorrow to see if pressure normalizes.
Thoughts?
The gauge readings are attached...
With what you said about the chewed up threads, it sounds like the first move is to get them repaired and then repeat the compression test; as you may be losing some PSI through the threads.
Fixing the threads might entail removing the head, but it's not a big job and it'll give you a chance to have a look inside for any potential problems you haven't been aware of.
