Is it normal for there to be a slight grinding type noise from the kick start when in neutral and driving. It almost sounds like the kick start isnt all the way back to starting position.
I replied this to someone else in case you've searched for similar posts.
My kickstart was making the same noise. It was permanently engaged and the only time the noise would stop while I was riding was when I put it in neutral. I had to replace the kickstart shaft and that solved my problem.
