75' cb500 battery and electrical
Hey!
I'm building a cafe racer/brat based on a 75' cb500. I'm putting in an entierly new electrical system, and I basically want to dubblecheck that the setup i have in mind will work! I'm going to be using a motogadget-m unit, and putting in a new ricks motorsport reg/rec combo. as for the battery i'm thinking about going with the antigravity 4-cell(i have extremly limited space for the battery), and it will be kick start only. It already has dyna-s ignition pionts on it if that makes a difference.
as far as I can see and what my research tells me i cant see why this stup would not work. My biggest concern though is that the battery is too small/weak(flicker in the headlight and so on when idiling is no problem).
so, if anyone can think of anything that could be a problem with this setup, please enlighten me!:)
That setup should work, but based on your selection of the m-unit (which is pretty high end gear), why not go with a better battery? We carry the earthX unit, which is a bit smaller than the equivalent antigravity unit and also contains internal electronics to protect it from both over and under-charging.
