'75 CB550 - Helga
countjugular
Hey all, I put my introduction in the proper area on the site http://www.dotheton.com/forum/index.php?topic=39170.0, and was asked for pics of the bike. Figured I'd start a build thread.
This bike was bought as a "parts bike" since the dealer did not have a title for it, they stripped the vin, and I picked it up for $250 (after seeing some of the deals you guys get on here, I probably overpaid). I still have not dealt with getting a new vin / title, but I'll cross that bridge when I get to it. Plan is, get the bike running / mocked up, do an MSO, if it is not going to work for some reason, find a titled CB550 frame to buy, xfer everything to it.
Here's some quick before pics (how I bought it)
Here's some pictures I snapped about 2 weeks ago
Tank is from a Honda 500t
Seat is homemade (in case that somehow wasn't obvious ... haha)
K&N Pods installed
Found all the pieces for the front brakes... .caliper was a bit of a pain, but ended up getting one in Albuquerque when I had to go for a wedding. Got some SS lines that are WAY too long, I forgot to measure before I drove 50 miles to get them, and the sales guy and I guessed way wrong on length ... oops
Electronics / Battery moved to under seat position
Tach removed, had to keep Speedo for MSO attempt
Bike at this point has been started, pretty much all it needed was some gas, and she fired up.... needs lots of tuning, but it runs, and not burning off anything funky that I can see
I'll go snap a few pictures of where it is currently at
Alright, now that I've caught up on posting the older pictures, here's where its at today.
I really didn't want to chop up the stock 4-4 exhaust, so I picked up a Jardine exhaust, that had the look I was wanting, but was way too quiet..... took the baffle out of the back, it sounds sooooo much better..... may end up finding a way to remove the rest, we'll see
Couldn't figure out why the bike never looked like it sat right, found that the stock rear wheel was an 18", and someone had put a 16" on this bike, so on another trip to Albuquerque (this time for a graduation) found a wheel for $50 that looked half decent. The stance is much closer, now for some longer rear shocks, and I think I'll be happy(er)
Made a switch plate, left switch, High / Low / Off for headlights, black button in middle = Horn, right switch, engine on / off
Things to do still:
New clutch perch to get rid of the blinker / headlight assy
Adjust valves
Check / adjust timing
Sync Carbs
Fork seals
Wrap the other 3 headers
Mount taillight
Make license plate mount
Shorten Brake line
Possible longer shocks in back (13.5" ???)
Find a way to make speedo cable not look horrid
Remove starter, make plate to cover
Remove tach cable, make plate to cover
Finish seat
Lots of cleaning
Lots of painting
New Rubber
I put a couple videos on youtube of a quick first drive of this bike.... it is nowhere near done, but couldn't resist, its the first time that it has been to a point where it could actually be driven. (my brother videoing)
http://youtu.be/Un9ZFzDu52I
http://youtu.be/WHWAnRQ3j74
As you can hear, the engine needs tuning
Rock on man! I think I'm hearing some lean carburetor jetting on that run (what jets you running now?) Keep it up, she's going to be killer, and I dig the name "Helga" for it. 8)
I'm running stock jetting (100) ..... I don't know much of anything, but I saw a chart once that indicated that's where I needed to be....
1 size up for pods
1 size up for 4-2 exhaust
1 size down for every 2500' elevation
I'm just over 5k altitude in Colorado
which brought me to thinking stock jets were right for me.
working on the bike today, I adjusted the valves, and am working on timing, and it looks like the timing was way advanced, fiddling with that now, hopeing that solves the popping. After I'm done with this, I'm going to sync the carbs then do a plug chop run and see where I'm at.
1 size up for pods
Ah, yeah timing and carb synchronizing may solve that. And definitely check the plugs, that will help. Sounds like you've got it all covered!
not sure I've got it covered, but trying anyway .. haha ... I'm extremely new to working on bikes, and carbs ....
I've got the timing adjusted, and from what I can tell synced (using closed loop lines and 2cycle oil), I don't trust my sync very much, and need to get some gauges, but should be fairly close for now. I'm still getting some popping out of the pipes,
I'm thinking that may be because I removed the baffle, but I'll have to deal with that "tomorrow". 2 4am nights working on this is having a way with me tonight, and I feel like just reading up on other peoples builds for a few hours for some inspiration.
I did however manage to get my taillight mount made today, not sure if its legal, but I like how it looks, hopefully the DMV will let it slide...
Pictures of the taillight bracket ... can anyone confirm or deny if its legal ?
Didn't know if it had to be on the center of the bike, if its ok that it is offset like it is, or if there are any height requirements.... hopefully this will be roadworthy soon, and I'll just "face the music" at the DMV
Haha well thanks man! It's just about done! I am so close on it! I really like your tail light idea. Super sleek. Where are you planning on doing your license plate?
License plate holder will be basically the same mount on the other side sideways, the taillight has some white LED's that I'm hoping will be bright enough to illuminate the plate.... if not I'm not to worried about it, cops in Colorado really don't seem to care much about license plate location / lighting on bikes. I had a yzf600r, and I had the plate tucked under the wheel on the splash guard, it couldn't be seen unless at the right angle, had no lighting at all, and never got harassed about it :) although if I thought about it, it could be because I play poker with a bunch of cops and ex FBI guys ... haha
Progress has been a little slow the last few weeks, I've been trying to figure out the jetting issues that are plaguing me.... mostly because I'm not sure what I'm doing. I have managed to decide that it is running lean, as was pointed out by MotorbikeBruno.
I have the air screw out 1.5 turns
I have the needle as far up as it will go (E clip on bottom of needle, was at 1 up on video)
Bike has stock Jets 100 / 38
The mods are K&N pods
Jardine 4-2 exhaust with rear baffle out
I live at altitude of ~5300'
I believe it is still running lean, and am looking for suggestions on what size jets to put in.
Also I noticed today, I put in fresh plugs and drove it around the block after adjusting the needle. 3 & 4 looked decent, but a little lean, 2 was very lean, and 1 appeared rich, float problem ?
Anyway here's some pics of the bike, I got impatient and rattle canned it since I couldn't decide what colors to do it in. I will be sanding and re-painting in a month or 2 with a kandy green stripe (there is history on the green). Will post them when its re-done again.
