Re: 76 CB360, before & after
SON OF A BITCH....YOU HAVE GOT TO BE KIDDING ME ?!?!?!
I got everything ready to close case.
cleaned bolt threads.
got my little map from the manual. measured and dry fit em, laid em out in order. w the 2 starter cable clips.
got thread sealant sitting there ready. kneaded tube to ensure mix
sockets ready
wrote down torque values. set torque wrench.
dry fit case.
blew bottom case w air compressor
cleaned mating surfaces w brake cleaner one last time
kneaded tube, opened and applied yamabond. nice even coat w brush.
fit case
installed all bolts
torqued to specs (6.5 lbs on the 6mm bolts sure dont feel like much...I couldnt even feel ratchet click...I had to watch for it to flex.)
wiped away excess yamabond. nice even little bead squeezed out.
completely satisfied w my work.
Breathed a big sigh of relief.
looked back at table....
thats a strange little spring...I dont remember that....Its one of the TWO springs off the cam chain tensioner adjustment bolt!!! Grabbed impact, pulled every bolt, pulled cases apart. wiped off yamabond w brake cleaner. Re-installed spring. NOW, Ill just wait til tomorrow to re-fit.
Ill use dremel to clean any yamabond I missed. I was glad to see only the bare minimum squeezed out into case. It was sure thin and super even.
sockets ready
dry fit case.
fit case
installed all bolts
