'76 cb360 not starting... need some help pleaseeeeee
mrhondada
Hey there DTT! i have been lurking on the site for a while now and finally made an account. I have recently picked up a 76 cb360 from a guy who had brought it down froma barn in new york, im in florida. i picked up the bike for $700 , on monday, because it wasn't running at the time. I took it home and replaced the plugs, and threw some new fuel in the tank and she started right up. I noticed that the right side exhaust was not coming out as powerful as the left. I had originally thought that was becasue the left exhaust is rotted out. I ran about 12 miles on the bike then i put it on the charger. I went back to the bike on Tuesday and she fired up the first kick then died shortly after. I pulled the plugs and the left plug was looking good, but the right was slightly black and had a small amount of fluid. Now she wont start. My guess is that i need all new electrical for the bike, stator, coils, plug cables. Im not to sure where to go from here. Im sure this question has been asked on here so any help or direction would be grealy appreciated.
also, he bikeonly has 10,000 miles on it. everything else on the bike is stock, except the pod filterson the carbs. the carbs have been cleaned and tuned. thanks for helping the noob out.
Engines need three things to run:
1.) Compression
2.) A spark introduced at the correct time
3.) The correct fuel/air mixture
1 and 2 are probably the easiest to check, so start with those.
1. Get a compression checker. They're like $20 or $30 on eBay if you don't have one already. Most auto parts shops will let you rent one, too. You'll want to be seeing around 150 PSI on each cylinder when the engine is cold and over 170 PSI after it's been warmed up. Also, each cylinder should be within a few PSI of one another.
2. First thing to check is the presence of a spark. Pull the plug on one side and then put it back into the plug wire. Touch the now removed plug to the side of the engine case (or other bare metal on the bike) while trying to start it and you should see sparks jumping from the plug to the bike. You want fat white or bluish sparks. Orange and yellow will sometimes work, but indicate a problem you want to handle. Provided you have sparks on both plugs, you should check timing next. Refer to your manual for this one or ask and I'll make a separate post.
If those two things check out, that leaves your fuel/air mixture as the problem. The first thing to do, if you haven't already done so, is to take off the carbs and give them a good cleaning. Remove the bowls, jets, and diaphragms but leave the linkage and butterfly valves intact. Next, separate all of the rubber seals and the diaphragms and set them aside. Now get a gallon of lemon juice simmering on the stove (this smell is one of the weirdest things I have ever experienced, be forewarned) and drop in the carb bodies and the jets. Let them simmer for 10-15 minutes and watch them closely. This stuff likes to boil over and it's a bitch to clean up. After they're done cooking, get them rinsed off with water, thoroughly. Pay close attention to the jets and other brass hardware. Any holes need to be spotlessly clean and you should be able to see light through any and all of them. Use the high E string on a guitar to clean them if still not perfect. Put everything back together and put it on the bike. Give it another go...
One of the most common reasons it fouling (either through carbon or oil). Make sure you're using clean and new plugs, especially on a bike with whose history you are not familiar. Check the points as well. If one side isn't gapped correctly, then that could also be the cause. If you're using new plugs and you know the timing is correct, you'll want new a new coil and/or plug wire.
Check the resistance of the plug caps. I think anything over 10ohms is too high? This solved a similar problem for me. I also removed the air filters and discovered that they were causing my 350 to run really rich.
Hope this helps.
that is along the lines i was thinking. its refreshing to know im semi on the right track. i was thinking of getting the DCC 5.0 ohm Dyna ignition coils and there new plug wires.
Don't just buy new parts and chuck 'em on. Find out the problem, then make corrections. New coils and wires aren't going to fix the problem if your points are out of whack.
all of this is very helpfull thanks i will check them out tonight and let you guys know any results. thanks again. its strange because the day i got it it started right up first kick and ran smooth. it has no electric start either, not sure it that matters.
