Actually it's not a bad base to start from. *Most* parts will swap to and from the more common cb450 twins. It's basically the same bike with a longer stroke, lower compression and milder cams. With the right parts swaps (OEM and otherwise) they can be made to scream right along. All the aftermarket bits that fit the 450 will fit the 500T including hi compression pistons since the bores the same, however you may need to shim the base of the barrels a couple MM if there's mechanical interference. The wrist pin is 2mm lower in the piston on a 500 motor so keep an eye on that. You may be able to clay the pistons and cut the valve reliefs a bit deeper. I snagged a pair of after-market slugs off ebay and was able to do that. Others may require the shim work.
Keep in mind, if you DO raise the compression a lot you'll NEED a hotter cam to keep cylinder pressures from becoming excessive.
Conversely, you could have your head flycut to boost the compression though you want to be carefull doing that as you can adversely effect your cam timing.
If yours runs good, you can do a lot with it for only a little $$. Start off by stripping as much weight off the porky little brute as you can. My roller is sitting right around 340lbs which is pretty light for a rig of this vintage and displacement. Things to get rid of to (relatively easily drop some pounds:
1) Electric started and internal bits that go along with it. Feel like getting really nuts? Pull the wiring and switch stuff related..
2) Airbox and battery cage. Throw some pod filters on and whip up an aluminum tray and strap to hold your battery.
3) Ditch that ridiculous exhaust. Not only is it pig heavy and over complicated with that stupid and apparently useless crossover, but it's really restrictive. Throw on some head pipes from a 450 and some Emgo short megaphones, lots of flow and low weight
4) Ditch the center stand....it's chubby.
5) Add some aftermarket mini-signals in place of the stock lollipops and any number of tail lights in place of the heavy stock unit and bracket.
6) Toss all the useless crap: side covers, chrome grab bar, any trim stuff......gone gone gone!
7) Ditch the stock speedo, cable and drive and use a digital bicycle speedo, get rid of the 'dash' and hang the key under the tank.
Basically get rid of anything that doesn't serve to make it go or go faster.
Want more?
-'glass seat
-bob the back fo the frame to the shock mounts (don't forget to add a loop between them for strength)
-'glass front fender
-ditch the rear fender all together but mount a light weight splash panel to keep road goo off your carbs
-switch to alloy rims
-switch to aluminum rear sets to cut a good bit of chub...the stock peg and brake pedal are not light....
It's limited only by your imagination really.
