76 cb550f
tonofun
I just did carb kits and cleaning on my cb550f....which by the way is a huge pain in the ass! I can not believe the linkeage, alignment etc. my question is, the bike runs a lot better now, but doesent seem like it will break thru 5k. Any suggestions. What is a good starting point on the air bypass screw(I think that's what it is in the side).just real quick I took some exhaust manifold temps with a gun, they are all very close. I did notice on my new carb kits the air screw in the new kits that goes in the side had holes in them vs the old that was solid. Not sure why. Any suggestions or insights would be great. Thanks
Have you modified the stock exhaust or air filtration? If so, you will need to use different size jets than those found in a stock carb kit.
Swan I have a single k+n filters to each carb, with the stock 4-1 header. I am at about 4200 feet above sea level. I have been messing with the adjustments and I seem to be getting it to start easily, idle nice and pull well from idle to about 4500 then it hits a flat, then pulls about 5500 and will continue to increase rpm, but hesitantly. I have not had the carbs synced, but that will probably be my next step.thanks
