LJWalter
I am sure this would be a simple fix for those with more experience, but I am in need of a little help. 77 cb750f leaking from overflow of carb 1. Drain valve is closed with a new o-ring. I pulled the bowl thinking the float was stuck in the down position. I pulled the bowl & insured the float was moving free and tested it with the fuel on, no problems. I carefully put the bowl back in place making sure not to make contact with the float. Fuel on, still leaking?..
Any help would be very much appreciated.
Thanks in advance.
Thanks in advance.
