crazypj
Split personality, I fake being smart
Re: '77 CJ360T (Café SOS) - Head and Valve Work Complete
I've seen it done with a Dremel (or rather a die grinder) but it sure isn't any kind of precision.
You have a couple of old bent valves (well, new bent valves really
If the stem is straight, you can cut teeth into face/head with Dremel and use that to open up valve pockets, the bend will give extra clearance on diameter.
Just fit in guide as normal, bolt head down and spin onto piston at TDC
Valve to valve you measure with the head off at overlap, fit really light springs and turn cam.
Just before and after TDC is the 'danger' area
I shorten cylinders to zero deck, have to build motor to find out how much you need to remove
