Hello. I have been browsing this site for a bit and decided it was time to put forth some questions.
First off, I will say that I have limited mechanical experience, just the basics. I have done some work and own most of the tools I think I am going to need. I am a quick learner, so I am not too nervous or overwhelmed and there are plenty of resources that I can turn too.
I recently purchased a 78 cb400 hawk 1. It is my first official bike. I am getting my endorsement in August and other than riding dirt bikes growing up, I have limited riding experience. So, I have plenty of time to work in this bike and I plan to take it slow all around.
Now, onto the bike. It was cheap, has a clean title and runs. I did some research about the bike before I purchased it and decided that it would be a good start. I bought it sort of as a half first bike, half fixer upper project. I have seen some posts about this bike being worthless, slow, no better than a pile of junk...etc. I'm fine with it, I'm not looking for a high performance machine right off the bat anyway.
I am not sure exactly where I am going with this bike. I want to do a cafe style bike and have thought a lot about seats, bars, etc. But, my first and foremost priority is getting it up and running, safe and solid...then I will kind of go from there. I tend to get ahead of myself and go full speed ahead, so who knows....but I do want to get it running and solid first.
The bike currently runs. Not poorly, not well either. Some issues I have noticed.
1. It is running rich (I assume). I put my hand behind the pipes and notice it is spitting fuel. Not much, but enough to notice on my hand. It has never backfired and sounds decent, so I don't think it is too bad. I plan to pull the bowls off the carb and just kind of go from there, but it could also be a valve issue.
2. Compression is low. I did one test and found it was 60 in the left side 90 in the right. I then realized i didn't open the choke and turn the throttle, so I re tested it properly and get 120 for left and 150 for right, engine cold. I used a cheap harbor freight gauge, so I will probably do it again to confirm what I found today.
3. The kick starter slips every now and then, like it is not grabbing. It works 95% of the time and starts right up, so I don't know if that is normal or what.
4. This is the big one I am mulling over right now. There is a loud ticking sound from the top end. I used the screw driver to the ear trick and determined it was mostly loudest at the top left. I adjusted the cam chain and nothing changed.
My next move is to check the valves. I have a shop manual that I downloaded that seems to spell everything out well, but I want to get the cover off and go from there.
Any advice, tips, general knowledge you can give me? Am I on the right track?
Also, gaskets.....can I simply make my own gasket and what thickness would work best?
I have posted this in another forum, so if your reading it twice, sorry!
Also, should I start a "build" thread somewhere to post my on going questions, or does this work?
Thanks,
Chad
I can't seem to attached a photo with the iPad, so I will get it up soon.
Thanks,
Chad
