hubbard_86
1978 Honda CB400A
Been a while since I have participated here but the weather is getting nicer in New England so I fired up the bike and she started up fine and idled great. Here are the symptoms though:
1. The bike revs fine when in idle but as soon as I put it in gear it rides extremely slow as though it was on one cylinder (more on this...).
2. I rebuilt the carbs this winter. Soaked them, air blasted them, new gaskets, new needles, new jets etc...
3. I checked the spark and it's strong on both cylinders.
4. The choke does NOT affect the engine performance. I can see the mechanism pulling on the spring but no response on the idle.
5. I noticed that when I turned the bike off, the left Cylinder exhaust was only warm to the touch. So I turned the fuel back on and took out the bowl drain screw and NO fuel came out.
So, I'm guessing the left carb is getting no fuel (obviously). But do I also have an issue with my choke connection? Or does the choke only affect the same carb that's not getting fuel? I think this might be the case but I don't remember...
Where do I start with the fuel situation? Maybe the bowl is simply stuck? Or is there a way I can try to get fuel to the carb without taking the carb out of bike (total headache)? Maybe I can blow compressed air into where the fuel hose enters the carb with the drain plug open? Maybe this would free things up... I'm open to any recommendations!!!
thanks in advance!
thanks in advance!
