78' CB550k Cafe/Brat - NJ
cgraham
Active Member
08886
1978 Honda CB550k
Cafe/Brat
Clean title in hand
12k miles
Closing on my house and need to sell. Built the bike over the past two years and hate to see it go. Only got a few rides on it since the build took so long to complete. I was running a lithium battery and did not have success with it, so the buyer will need to fit a battery and investigate the regulator/rectifier unit that I installed - and that is reflected in my asking price.
Parts List:
Billet top triple ($130)
Polished rear shocks ($140)
Aluminum Clip-On bars ($135)
Leather wrapped grips ($30)
Clutch and brake levers ($35)
Leather wrapped levers ($20)
Billet side view mirrors ($220)
Metal bar end adapters ($40)
Baits headlight ($115)
Billet headlight bracket ($30)
Spoke wheels (refinished-$200)
Michelin Tires ($240)
Velocity stacks ($95)
Custom exhaust ($30)
Aftermarket header ($220)
Fiberglass wrap on header ($50)
Custom vinyl seat ($175)
Custom plasti-dipped tank ($40)
Honda badges ($40)
Custom electric box ($60)
Lithium charger($100)
Custom mini battery box($60)
Aluminum rear blinkers ($40)
Aluminum taillight($110)
Aluminum plate bracket($25)
New hoses($20)
Crank case breather ($10)
New shortened clutch line($30)
Custom ignition switch($25)
Misc. hardware ($100)
SparckMoto reg/rect ($100)
And more...
Will also throw in the Bitwell helmet and gloves shown in the pictures ($260 value) for an additional $150 - Both nearly brand new, used for only two rides.
Some of the work done in addition to installing above parts:
Modified rear frame.
Welded crossmember for support.
Welded battery box to swing arm.
Removed frame tabs.
Frame sanded and painted gray
Cleaned up and polished motor
Tachometer/speedometer delete
Horn delete
Sanded and sprayed tank
Wiring removed from oem headlight
Wiring hidden under tank/on frame
Cleaned up, replaced, shortened, removed excess wiring.
Electronics hid under seat
Custom ignition toggle in electronics tray
Polished fork tubes
Lowered front end.
Painted front brake assembly.
Relocated custom choke to carbs
Cleaned rear drum/hub and polished
Polished front brake disk.
Cleaned and greased chain.
Tons more totaling over 300 hours.
Definitely taking a loss, but...
Price:$3500
