'78 KZ650B Cafe Project
sbruton
Where the fvck is that money you owe me?!?
It's cold, snowy and generally shiddy weather in Alberta today so I thought I'd take the opportunity to say Hi, and start a build thread. This is my first post here, but I've been watching a few threads and getting inspired by all the cool projects. I've been seeking help at the kz650.info site on general KZ650 "stuff" and I see some of the fellers from there also post on this site. Everyone has been very helpful - Thanks!
So... my project started life as a bone stock '78 KZ650B with (what I've been told) is C bodywork. It was "yard fresh" and hasn't been run since 1996. I got the bike plus a shiney red hydraulic bike lift for $400. I thought it was a pretty good deal, so I brought it home and started to tinker. The seat was completely trashed, but the rest of the bike was in excellent shape considering it has sat for such a long time (outside).
My original plan was to get this bike running well and then use the parts to build a bobber. (If you look close in the pics above you can see my HT frame).... Once I started working on this the plans have changed somewhat and now I'm heading down the "cafe" path. I plan to revisit the bobber project once this one is "complete"... if that is even possible?!?
A new battery, cleaning and repairing the carbs and a general cleaning it fired right up! I couldn't believe it... ;D Lots of smoke and general crud came out of the pipes for a while, but an oil change and a few laps around town it now runs great. No smoke, good power and runs smooooooth! Wicked. Then I started with minor tweaking and making some mods.
Pulled the front fender, rear fender, chain guard, air box, modified the tail light and did a quick reupholstering job to the seat so I could get some short rides on it before the snow came:
Once it cooled off and time permitted, I made a few more changes. I made a fibreglass seat pan (with new foam and covering), a buddy and I "welded" up a metal frame to support the pan, moved the tail piece forward and installed a new tail light with small signals. I also picked some some new 11.5" rear shocks from MikesXS...
New Tail Light Assy (I've since put on flush mount signals beside the tail light)
Seat frame
Temporary Seat - looks comfy, huh?
Since then, I put on clubmans, removed the gauges, installed a mini speedo, moved ignition key to headlight bucket, new cables and started to reroute all the wires etc...
With the side panels still on:
The next step is to make a proper cafe seat, and install a small gel battery somewhere hidden... The ulitmate plan is to remove the side panels, cut the tabs, and rear subframe, hide all the electrics and give it that traditional "cafe look" . Winter is here in Alberta, so progress will be much slower due to the cold weather and no "proper" heat in the garage....
Thats all for now....
Feedback, suggestions, comments are always welcome!
Thanks for checking it out!
Re: Another '78 KZ650 Cafe Project...lots of pics
"Welded"? Bah...next time bring more beers! And not Winter Spice! Bleh!
it's looking good, can't wait to see the new seat when it's done.
Agreed. I was going to use your line.... "sticking metal together" but didn't want to blow our cover! ;D
Started to work on the form for my cafe seat last night...
I picked up some sheets of SM insulation and a can of 3M Super 77. First of all cut some rough sized pieces and glued them all together:
After some rough dimensioning/ cutting with a handsaw , shaping with a small rasp and making one helluva mess in the garage, I ended up with this:
Tonight I hope to reshape it a bit, and lower the hump an inch or so. It's sitting a bit high at the back because the form is resting on the cross brace of the sub-frame...
What do ya think?
I did a bit more shaping and sanding of my form last night and I also cut the rear loop off... seems to be coming along:
I plan to blend in the nubs a bit better, but this gives a pretty good idea of the concept.
I think I'll round out the back a bit more so it's kinda like this:
Thoughts?
Nothing to report... :'(
I'm hoping to get a little bit done this week... maybe even tonight. Other "things" getting in the way of garage-ma-hall time!
Well... finally got some time today to do a bit more work.
First off, I finished taping my seat form and waxed it a handful of times (to keep resin from bonding to it)
Then, I hauled out the grinder and cut all the tabs off the frame. I still have to grind them smooth but I think it is starting to come together:
Then, I put the first layer of glass on the form:
I'll let the first layer cure of for a while before adding more glass. I used quite a bit of resin and a small foam paint roller to move it around. It seemed to work quite well and keeps the mess to a minimum. So far so good...
Now time for some beers! ;D
looking like some good progress. when using resin you only need a little more resin than it takes to saturate the fiberglass. if that makes sense. sometimes it is easier to cut out your fiberglass pieces and saturate them in resin before putting them on your mold. a piece of glass works really well for this.
Thanks for the tips dcmspikes... I may try that next time, using smaller pieces of glass.
I haven't had any time lately to lay on more layers but will be a little less liberal with the resin application when I get a chance! Believe it or not, I used a full 946 mL can of resin for the 2-ish layers of glass matt that I've layed up. :o
The good thing is, it is quite smooth!
nice work with the glass, looks great! do you plan on attaching it to the base of the stock seat and hinges?
Thanks!
I finally did a bit more to it this weekend. Pulled the plug out - what a bitch of a job that was! I ended up cutting the form to bits and then poured acetone on it to dissolve the foam. It's all out, but I guess I can't make another one unless I use my existing seat as a mold.
I have cut all the tabs and stock seat mounting brackets off. I plan to weld a couple more cross pieces in and then weld in a sheet metal pan that I can bolt the fibreglass seat to.
I think I will glass some mounting bolts directly through the seat. The battery, and some of the other electrical bits will be moved under the hump.
Maybe I'll get a chance to lay up another layer tonight...
Re: '78 KZ650B Cafe Project - raw fibreglass cafe seat done!
Well... I finally got the raw fibre glass seat layered up and shaped the way I want it. Before I get into filling/ sanding and painting I plan to tackle the electrical and put some thought into a tail light and figure out how to mount it.
What do you think?
very nice. my seat pan just rests on the frame rails with some velcro tape. actually works much better than you'd think. if you get a chance, can you post a pic of how you have your key/ignition setup? the stock gauge cluster/idiot lights ugly up the front end of my bike and I think I'll eliminate them next.
HerrDeacon - thanks for the compliments!
bbillington - I may give the velcro a try.. I have some 3M Duallock which is industrial stength "velcro" type stuff. The pan fits quite snug so it's just a matter of holding it in place - Good call!
For the guages I basically removed that entire pod up front, flipped the headlight ears over to drop the headlight bucket and bought a mini speed to replace it all. I drilled a hole in the back of the headlight bucket and relocated the ignition switch. It seemed to work ok. I don't plan to replace the tach and will seal up the tach drive at the engine case.
Here are some pics:
Looks good. a little worried about the clearance between the rear tire and the seat. I'm thinking one good shock compression, and you won't have that seat for very long!
Yeah... I was looking at that too. I'm pretty light and those friggin' shocks are hard as rocks so I'm hoping not to hit - but for the sake of some extra clearance I might trim the tail up a bit more!
Maybe follow the line created by the upper shock mount location? It's got a nice upward sweep, so you could follow it, and that might just take enough off the back of it to buy you just a tad more wiggle room. Hard to tell from here some of the details.
