79 cb750 basketcase
hey, used the steel wool on them tonight and after less than 30 secs they were great, no pitting that I can see and no other marks etc. i'll check out their measurements and see what its like before deciding what to do!!
Dont know of a specific one for the Cb750, there are plenty of generic ones youtube. Personally I just keep everything from the carb together to it goes back in the same carb on assembly and use the parts diagram to help with assembly or a multitude of photo's taken before and during dissembling. Just beware of the throttle linkage springs making a bid for freedom.
Tore down the spare and got the motor out ready for soda, i think the spare was an ex police bike as it looks like it was painted white. Im going to look ay swapping over the front end as its a twin disc.
Also gasket set arrived today. Soda is booked in for the 13/6. Lifting these motors by myself is killing me!!
Nice thread so far. Couple of suggestions. I use "High Temp Lab Metal" body fill for lots of things. You can fix those tank holes, patch an exhaust, powdercoat over it, whatever. I get it from Eastwood.
Also I hear boiling lemon juice in a pot with carbs in it works awesome. Also clean all jets etc in lemon juice before resorting to rebuild kits. 99% of the time you don't need new guts. I was spending big$ on ultrasonic cleaning and kits until I found this out.
Sanded the tank a little, am thinking two tone. Clear over the bare polished metal down the center and then color on the sides?
Still just an idea but we'll see.
Cheers HD, well i said at first that i didnt have a time limit for the build. Well i have now!!
Needs to be done by 27/12/13, the due date of the new baby!
Took the motors and 1 frame to be soda blasted today, i was a little dissapointed with the results. The frame was not taken all the wayback to metal and he missed lots of areas :( the motors came out ok but another guy who turned up with ariel square 4 parts turned around and left as he thought the finish wasnt very good. The end result is that the powdercoaters have to prep the frame so more$$$!! :-\
My buffing efforts are a reflection of my lack of a buffer
I picked up a bench buffer/polisher really cheap at harbor freight. However if I could go back and do it again I would spend the few more dollars and get the 1hp one compared to the 1/2hp I got. It does the job but softly underpowered.
Sent from my SCH-I535 using Tapatalk 2
The frames back from the powdercoaters, am starting to get pissed about things being missed, there is an area that they missed and an area they blasted a hole through in the weld in the hoop grrrr.
Painted the cases and have to now wait until the wife goes out before i bake them!
Im just about to start stripping the fork legs , once they're done i'll decide whether to paint or polish them. Next is to think about the seat. I wish we had a harbour freight in NZ!!
So far our bikes are very similar except for SOHC. Check out what I did with my forks. I did them in a red/polished mix.
http://www.dotheton.com/forum/index.php?topic=50224.0
I feel for you with the powder coating. I had the same problem, they blew through a weak part near the footrest mount and has speckles of a different colour on it. I took it home repaired it and got them to recoat for free. They should of told you of the damage after blasting and before coating. Well they would if they were a half decent company.
It looks good in the photo.
im kicking myself, I was taking the bottom case back to the garage after baking it and dropped it!!!! It looks like it has dented in the case just a little but it still lines up ok with the top half! Another development is..... im buying another bike its a 96 ducati 750ss in great cond. I just have to settle the finer details with the seller and arrange to pick it up pics as below
