cameron750
Hey guys, my first post on the forum. Need some input from you guys. I am a new generation car mechanic, and while I have decent grasp on working with multiple carbs, points condenser and mechanical advance timing, I find myself shooting the breeze with the old school guys in my shop to learn as much as I can on last generation engine performance and tuning.
I have a 1979 GS 750E - engine is all stock save for a pair of unknown brand 2-1 headers, and K&N filters. The previous owner told me that the bike had about 14k original miles when I bought it, I have put about 2k miles on in the past two years I've owned it. It's not on the title how many miles it has, so I never really believed the story - but I digress.
Maintenence on the bike has been nothing out of the ordinary over the past two years. When I got it, I sorted through the engine to make sure it was up and up on the maintenence - changed the oil, adjusted points and timing, synched and tuned carbs, adjusted and lubed chain, etc. The only thing I never did was adjust the valves because based on what the previous owner told me, as well as by the new valve cover gaskets, it was just done. I should also add that the previous owner had put drag pipes on, and did a pretty cheesy mounting job on them, leaving them too low that when I leaned the bike over they would scrape the ground and unsettle the bike. For lack of a better way of preventing this, I took off the mufflers and ran it straight header exiting just below the rearsets until I could find a better solution. Rode like this for approx 1k miles.
Fast forward to about three months ago, I started sorting the bike out for the riding season. Checked carb tune, adjusted points and timing, as well as new NGK plugs. Everything was great until halfway into a 40 mile ride, the bike started sputtering out on me whenever the timing curve advanced. I messed with the carbs on the side of the road, and then I nursed her home, not sure where to start. The next weekend I had the time to check the bike out again, and decided the best course of action would be to reset the points and timing and try again. I test rode it up and down my block, and everything seemed fine. I knew I had just set the points about 150 miles earlier, but that seemed to fix it. I did a few short trips putzing in town, but nothing long distance. The next weekend, I took her back up the mountain and once again, just about the time I reached the half way mark, sputtering out again. Figuring it was the points again, I let the bike cool down a couple hours and with a matchbook and borrowed tools, I reset the points. Rode most of the way home ok, and then again, sputtering. Got it back home, rechecked it the next weekend, and then the bike sat. About two weeks ago I had an emergency at work that required my presence in the shop ASAP. I hopped on the bike, and hot rodded to the shop, took care of what needed to be done and then cruised around town a bit. I was getting really hot, so I decided to head in for the day. A few blocks from my house, it started pooping out again.
At this point I was sold on an electronic ignition setup, and a couple days ago I pulled the trigger on a Dyna DS3-2 setup. So for the past couple days, I’ve been waiting on the package on the mail, and decided to look around the internet for more info on my bike. I came across an old forum post from someone complaining about their bike running great, and then as soon as it had been ridden for about twenty miles or so, it would start sputtering out – just like mine. I decided to go ahead and try riding the bike from a dead cold, and sure enough, after giving it a proper initial warm up cycle, it pulls just fine all the way through the advance curve. The replies to the post suggested that the bike may have a burned exhaust valve. This got me to thinking that hot rodding around on straight pipes may have damaged one or more of my exhaust valves, causing it to not seal properly when the engine is hot.
Some important notes to keep in mind are:
-Only happens when the bike is hot, ie. 20-30 miles into a ride, dead cold is just fine
-Engine is stock save for 2-1 pipes with no mufflers and K&N filters
-Carbs and ingition are in good working order, no vacuum leaks
-Valves are presumed to have been adjusted approx 2k miles ago
Am I heading in the right direction? My next steps are going to be compression check cold and when the condition is present, as well as check and adjust the valves if needed. I suppose I should check my advance timing when the bike is sputtering to rule out bad governer weights. I’m going to hold off on installing the new ignition until I find the exact cause of my problem just to keep the variables down. I really wish this would have happened more towards the end of the riding season, because I had been planning on yanking the engine and spend the winter inspecting and resealing and dressing the engine anyway…
What would a first post be without pics of my bike! These are the photos from the seller 2 years ago – the bike hasn’t changed save for the removal of the mufflers. I have plans to redo it, but when I got it, I was looking for more of a turn key bike that I wouldn’t have to build myself.
Thanks,
Cameron
Thanks,
Cameron
