Need help with electic issues please!!
my first cafe' project...i have some questions if anyone could help that would be great...
First problem is i have no spark...the start button does not do anything and lights and turn/horn dont work either...battery is good. so i have some electric issues
****rechecked to see if spark at the points...nothing...i cleaned them and all but still nothing down there..???
i assume i have a connector not workin...?? what do i check??***
when i jump across the starter "relay/sylinoide thing" not sure what its called yet...anyway when i jump the 2 contact posts it will put juice to the starter and it turns pretty nice..
has not started due to no spark but i have rewired a few things already...and have been cleaning as many contacts as possible...putting some dielectric grease on some parts..
trying to go threw the manual now but could use some insite as to maybe some info on how to use my meter to get some readings with it to tell me whats good and whats not for my no spark issue...
i removed the air box and want to know what everone does with the hose that used to connect the bottom of the air box to the motor..(breater maybe)...do ya just plug it up?
i also have a seperate starter issue....when i get the starter turning it will turn over for 2 seconds or so then something slips not sure if its a gear slipping im not sure....i pulled the starter today and all gears looked in good order...the gear on the starter and the 2 gears it hits all looked in good shape...something is deff. not sounding good....any thoughts?
thanx in advance for any help u can give me...
