79 xs650 cold exhaust on one side at idle
sevenhillsbilly
suject says it all at idle i have cold exhaust at idle and once i hit the gas it clears up i bought a digital ignition system to see if that helps any ideas would be greatfull!!
How were they cleaned? It still sounds like a blockage in the pilot system. Either in the air jets or the tiny discharge holes or bypass drillings.
Simple test. Remove the carbs and pop out the mixture screws and springs and spray carb cleaner in through the mixture screw hole. Repeat on the other carbs and compare flow. I suspect that the cold side will not spray as well/at all.
If they are the same, remove the float bowls and spray in through the air jets and then up from the tiny drilling above the pilot jet.
All the above assumes that you have already tried adjusting the mixture screws first
