My latest project is a 79 CB750K advertised as having rebuilt carbs and being driven. True story is the carbs were rebuilt 2 years ago and it had sat ever since. It has pods on it and would barely fire and run, let alone drive. I drained all the gas, drained the carbs, cleaned all the sediment out of the bowls, reset all the float heights (all were different :
), put in fresh gas and crossed my fingers. It now will start on the first or second try, idle like a champ, rev ever-so-slightly, drive but it is boggin in the mid-range and if you can get it to rev high enough, scream on the top-end. What am I missing as far as the mid-range and transition to high-rev operation? I do need to double check the timing to make sure it hasn't been tinkered with but I still think most of the problems are in the carbs. TIA
