J-Rod10 said:It's 40 year old lines/calipers.
Personally, I'd rebuild the calipers, rebuild/replace the master, and get new lines.
dmable44 said:Or would it be better to buy some used ones in better shape? Or is that not worth it
You're an armchair mechanic at best and that's being generous so I dont know why you constantly argue with someone that does this every day for money.hillsy said:Welcome to the real world.
The caliper body is the least of your worries. The pistons and seals are the concern.dmable44 said:There definitely is a lot of corrosion all over the calipers. Theoretically speaking, once the calipers are torn down could you blast them with media like walnut shells to make them fresh again?
Yes, measure, match your banjo fittings, and order.dmable44 said:Are braided lines something I could do myself or is a professional recommended? I'd love to overhaul a lot on the bike, but that will be next winter. I want to get it running and stopping safely just for this season to make sure the motor and trans is good.
DohcBikes said:You're an armchair mechanic at best and that's being generous so I dont know why you constantly argue with someone that does this every day for money.
Professional powersports mechanic that works on the #1 brand in the world 45 hours a week, not sure how much more real it gets.
Any shop that complains about any labor is a waste of your money.
hillsy said:Do you know how hydraulic brakes even work?
focusinprogress said:I probably should've checked here before responding to your PM. can you post a pic of your original mounting collar hardware, and measure the depth of the stock half-moon pieces? I'll see if I have longer ones. Either that or look for the spot welds on that fatter collar from your old exhaust and drill the spot welds out, cut the collars in half, and weld them back together on the new exhaust.
