81 CB750K Cylinders 3 and 4 Run Lean
oldsoulcole
I have an '81 CB750K that I recently re-jetted to accommodate for my 4 into 1 exhaust. I installed #72 primary jets and left my secondary jets alone. I did this because I was not lacking power in the higher RPM's (4,000 and higher). But before re-jetting I had a lot of hesitation anywhere below 4,000 rpm and could barely keep it running. After re-jetting nearly all of my hesitation is gone and takes off from a stop very smooth. It even idles! ;D But the problem I am having now is that cylinders 3 and 4 are running lean. I sprayed carb cleaner around the intake boots to see if any were leaking and got nothing. Just so you know where I am at I have the stock airbox, all 4 carburetors have been rebuilt and cleaned, synced, and new air box - carb boots installed, all cracked vacuum lines replaced, float heights are within spec, pilot screws are out 1 1/2 turns out, new exhaust gaskets installed, engine is timed correctly. I honestly do not know what else to do to try and solve this problem.
Will turning my pilot screws in cause my air/fuel mixture to become richer because that will be restricting more air to that cylinder? Any suggestions is greatly appreciated. I've done everything I can think of at the moment.
How do you know they're running lean? I assume by reading plugs? Does it run good? pilot screws will adjust mix at idle and low throttle openings. What rpm range are you running lean in?
in addition can you post photos of the plug tips . . use flammable brake cleaner with the long nozzle and spray gently for the air leak testt . . if you are near sea level you should g up on he mains 1 size with headers irregardless of how it runs . m if there is not air leak simply jet the lean cyls 1 jet richer in the lean area no big deal.f
The pictures go in order from Cylinder 1,2,3, and lastly 4. I am going off of what the plugs are telling me and the difference in heat. If you put your hand by cylinder 1 and 2 head pipes they feel normal. When you do the same by 3 and 4 they are much hotter. Recently I have also re-jetted and am now running #75 mains. This definitely made a difference because now the bike has zero hesitation at low speeds and rpm (10-25mph/ 1,500-4,000 rpm). It feels just as it should to me all the way through the powerband it pulls and it pulls HARD. I also sprayed both sides of my intake rubber boots (airbox to carb and carb to intake manifold) and I found zero leaks. I have tried making adjustments with the pilot screws and it makes little to no difference from what I have found. So will it not throw things off if I am running #75 mains in cylinder 1 and 2, then jump up a few sizes in cylinder 3 and 4? Also, the weather has been really bad lately and I have only really been able to run it in the garage. I would like to take it around for a few laps on a nice day and see if it does better. Because last night after I put the new jets in, it was raining and late I took it around the block once and when I pulled into the garage 3 and 4 didn't feel hot like before!! They felt nice and cool like cylinder 1 and 2 but the plugs said otherwise. The plugs showed cylinder 3 and 4 as still running hot.
you did not use flammable brake cleaner for your test, therefore your test is inconclusive, its that simple, but if it idles smooth i doubt it has a leak.
jetting your cylinders so they all have the same afr will make it run better and more even . . running them uneven like they might be will not.
dont ask me why these two look different than the others, i dont know for certain, but it sometimes happens . . i just have never seen it happen to this degree . . could be the carbs or could be the header design . . it is what it is.
by the way...the first two plugs are a bit rich and/or it is burning oil which looks more likely to me.
i would go up 1 size on the main on the lean ones.
if your needles are adjustable i would raise them all up 1 clip . . if not, i would increase the low speed jet 1 size.
this is the only way to know exactly what your gas level is . . they must all be fairly close.
..................here's an example of it a little too high . . it should be just below the solid black line in your case.
.................................................here's another and you can see the is level way too low.
[/QUOTE]
