'81 Honda CB50 turned Cafe (build thread)
kylemason
Hello,
Bought my bike yesterday and am remaking it into a cafe racer with a mono shock , new subframe, and new tank.
I am making a thread mostly for the occasional assistance and then eventually to post parts I have and don't need for cheap.
I am looking at tanks and want one that fits with no alteration to the tank or frame, I can make new rubber dampeners for it to rest on the frame but would prefer to not have to chop up the tank to fit. I like the look and shape of the Benelli 260 tanks and believe that it would be wide enough to not look silly on the 1981 750's frame. I have heard that they can be a pain though to get fitted on the frame requiring a bit of modification.
What tanks have you used for your cafe build and what work well?
Kyle
I like the stock tank on those bikes.
This is the look I'm going for with the tank. The mono shock will be set up like the one in that pic too
Those are bad, bad examples to pattern a build off of. They are not rideable. They are art bikes.
J Rod, building is as much an art and it is for riding, you don't even know my size or stature so you can't tell me what is ridable and what isn't.
.....shouldnt you be machining rearsets or something?......
A chipmunk couldn't ride those bikes without bottoming out the suspension. Some things just don't work, regardless of size and stature.
Welcome to the site. :)
WARNING: There are some nice folks on here who will try to help you survive and may offer advice even if it is not what you were hoping to hear.
If someone offers a little constructive advice at least give it at least some consideration. They may be right, and that still doesn't mean you have to change your idea. Just give it a thought.
Also there are 142 pages of cafe build therads on this site. There are tons of good and bad ideas there. Either way it's good reading. There is very little that hasn't been covered by someone on here. Look at the ones that are only a page or two long and avoid whatever mistakes they made.
Agreed that both bikes could use better suspention and may be more show than go.
You can get the look but the level of construction and design will be tricky. If you want to actually ride it for any distance that is. Well and safety might be a concern, but if you don't want to ride Very far and have no real fear of death or dismemberment then might
I suggest skipping the mono shock and go hard tail cafe. 8) you'll probably still have an accident but it won't take you two years to get to it. Sorry just kidding.
Good luck with the build.
That's a CX500 tank, I believe the Deluxe. Custom had a smaller tank.
Nothing against monoshock builds, I think they look sweet. Just make sure you actually do the homework and understand the forces at play in a full suspension bike before chopping off a properly engineered suspension and replacing it with a shock laying sideways because monoshocks are cool.
Obviously we don't know enough about your background to properly judge your abilities or knowledge on motorcycles, or mechanics in general. I suggest posting something in the Member Intros so people can have a better idea of who you are.
One last note, even though some people here will come off as knowing everything, keep in mind a lot of people on here have many years of knowledge and experience which they are offering to you. Sure it may not be what you want to hear, but when they say stuff its for your safety and to maximize your experience with your bike. Take everything with a grain of salt (its the fucking internet!!) and don't be afraid to call out someone on their advice if you have the experience or numbers to prove your point.
End long winded response :P
Hi kyle, look forward to the build thread. Is it a CB500 you're working with (title says CB50 but I figure that's a typo)? Nice choice. That is indeed a CX500 tank on that first example. The cb350F tank has a nice shape too, and has the 'knee dents' you seem to be after. Scale may be an issue, because it's not as large as the CX unit. Fits a 400F pretty well but.
Here's a pic I pinched from a member here as an example http://www.dotheton.com/forum/index.php?topic=65356.0;all:
index.php
cheers
ian
I think maybe the typo was meant to be '81 CB750. I believe that CB500's were only made up until '73 or '74.
It's your project, do what you want, but the above comments about your inspiration bikes are good points & are only given to help you avoid making mistakes many others make - I say appreciate the advice this forum has to offer.
If it a DOHC model you have, there some inspiration to be had here.
http://www.dotheton.com/forum/index.php?topic=44355.15
Wasn't trying to be a dick, so, sorry if it came across that way. The second bike you posted, Mike Le's, is a work or art. A beautifully built bike, just not one meant for regular riding. The first one, though, atrocious, trees dropped on the forks, a good two inches of clearance in the back.
There is nothing wrong with building an "art" bike, but don't expect to actually ride it much.
Build a bike that rides, the look will follow suit.
Not so much. J-rod was not commenting about your size shape or ability. His comments were related to the fact that those bikes may look inspiring to you but he sees serious design/fabrication shortcomings that make them unsafe or uncomfortable. Unsafe is simply unacceptable and uncomfortable means that the bike won't get ridden.
Of course you want a bike to look good, but most neophytes are not designers and are not engineers and a 100 mph two wheel device is not something to be attacked without a basic understanding of what works and what doesn't.
There is a basic rule with mechanical devices and that is "form follows function". That can mean that if it works right, it usually ends up looking right. It also means that looks are less important that how well it works.
All motorcycles are a compromise - or a series of compromises. Nonw of us, well most of us, are not building race bikes but that doesn't mean we can do without suspension or adequate brakes and making less power than stock doesn't make much sense either and yet many "cafe racers" fail in all categories.
Building something to put in a show or to get into pipeburn etc is fine, but those are typically not bikes that can be ridden safely for any distance.
So, looks are fine but function is the most important thing. Play with ideas on paper/PC and ask questions and do lots of research. Look at bikes on line and on the street and see the difference. I see lots of custom bikes on line and I see very few on the street or even outside. There's a reason for that.
Good luck and have fun.
Correct, the bike is a 750. Trust me I will be looking into the engineering of whichever suspension type I chose, but I won't be leaving the original I'll tell you that. I will also be looking into Buell type options having the shock under the chassis.
As for this I believe that if you design the mono in the similar way to bike that come stock with the mono shock and use a shock with an appropriate compression bottoming out the shocks shouldn't be an issue as the physics are transferable
- thanks though
- thanks though
That doesn't much change the fact that the bikes you posted as "inspiration" are lowered, entirely too much to be safe, or really rideable. It sounds, judging by your first response that art is just as big a part of it as function, that you're not all that in to function. If that's the case, have fun, try not to kill yourself.
Do you have experience in fabricating frame work? Bracing, experience with these old noodly frames that aren't designed to take the forces of a mono in general? The vast majority of these old bikes that are monoshocked are shoddy at best, look for inspiration in well built machines, vintage race bikes, etc, not something you saw on Pipeburn or Instagram.
You seem a little butt hurt, just offering up some advice that will save you a headache or two later. Nothing more, nothing less.
Check out www.caferacer.net Some of the guys over there may be able to offer some advice on how to go about getting the look of the two "inspiration" bikes.
