81 SR250 Carby problem!!!!
PocketsVIC
Active Member
Hi,
I was in the middle of re jetting my carb and was going to move my E clip down one notch on my needle in the slide - if that makes sense- when I took the needle cover in the slide off my spring, spacer, washer & needle all flew out and now I don't know what order they go back in so basically I'm f#@$ed.
If any one has any idea what order they go back in on a stock Makuni BS34 carb off a 1981 Yamaha SR260, It would make my day and I would forever refer to you as "KING OF THE CARBS"!!!!
Cheers
needle with the spacer as you have it first then the washer then the spring
