hello guys!
I recently ran into the same problem as my xj550... push button wont allow my bike to start (literally happened no more than 5 minutes after riding and worked fine before)
what happens when I press in the button is...
- I get the low oil light with start button pressed in (which is normal)
- when start button is released the solenoid does click
what I checked so far is...
- I CAN arc the solenoid and starts up no problem
- is in netureal
- checked main fuse along with fuses under headlight
- cleaned off battery terminals
- cleaned and checked connections on the right hand handlebar controls (all connections are perfectly clean)
- rocked bike back and forth in 2nd gear and tried starting
- cleaned solenoid connections
any help or input will be greatly appreciated on helping me with troubleshooting the virago (Im sure others ran into this problem before with these bikes)
- is in netureal
