81 XJ 550 Maxim
abnab
gotta start somewhere
I just got my first cafe project. I have been compiling parts bikes for a little while now, but I have finally stumbled on a bike that I want to begin my first "real" build with. The Yamaha XJ has been sitting in a barn for the last 10 years and is complete and running when parked. I am going to take a bunch of pics this weekend in it's current condition, before I start tearing her down. I also wanted to gain some insight from everybody here who might have some background with the XJ's or might have some ideas to help me get started. I did a search, but I couldn't find any pics or threads of any XJ builds, but then again, I am a noobie, and there is a lot of info on this sight.
So, here I am guys and gals...... Help a rookie out will ya? ;-)
AB
Dont know too much about the Maxims, but they sold a ton of them so... Im sure you could get a nice bike built if your willing to put the work in. On a bike like that, youll find that a lot of stuff will have to be custom fit or made for it.
Get some pics up here and keep us up to date. You'll find plenty of help if you ask.
I've had a bunch of Seca's over the years (3 x 900's, 1 x 750) and they are pretty robust / reliable. Although your bike is a chain drive, it still shares the same engineering as the bigger shafties - and the 550 was quite a fast bike for it's time.
Have a look at XJbikes.com. There's a heap of maintenance info over there for all the XJ's including the 550.
The main problems you will encounter with a stored XJ is gummed up carbs and leaking fuel taps (they notoriously drop fuel back through the airbox into the sump). Also the fuse boxes are renowned to let you down when you are farthest from home (change it out for a blade style fuse box)
Fix those things and do the normal maintenance (check / adjust the shims, synch the carbs) and it should be good to go.
i did an 81 xj550 last year
if you can pick up a seca tank they work much better as a cafe tank
here's a pic of mine
Thanks for the advice hilsy. I will follow those suggestions for sure, and I will check out that web link as well. And to you mrkil....... I love the way your bike turned outi! I agree about the tank... Finding a new tank is definately a must! I am assuming that your bike is sporting a seca tank in the pic? Did the tank have the kneewells like that, or is that something that you created yourself? Did you take pics during the build and post the progress on this sight? I would love to follow that build from start to finish.
After seeing your pic, I am even more excited than before! I took a few "before" pics today, and I will post them up on Monday so you can see where I am starting from. It's pretty scary right now, but you've gotta start somewhere right! ;-)
Hey man, you can have a look at my SECA build as well. Not exactly the same as a 550 Maxim, but almost the same as the 650...
Link is in the signature below.
Have any luck with the pics?
So I took a few pics of my 550 project. This is just the way it came out of the barn. I made sure not to wipe any of the dirt off. I wanted a visual of where this all started. Now, the fun begins! Im gonna move this over to the "big arse projects" page to begin the transformation.
Look for "AB's 81 XJ 550 Maxim"
Thanks for the link Ease. I loved reading through the posts and seeing the pics of your build. Your bike turned out great! I hope I can do as well as you and mrkil!
Yeah im pretty excited to get started. Im gonna be traveling with work the rest of this week and won't get to look at it again until the weekend. This might take awhile, but it should be fun and a great learning experience!
Nice abnab. I'm starting my first cafe racer build. I'm working on a 80' Yamaha XJ650 Maxim. I'm curious if the Seca tanks have the same mounting points as a Maxim tank. I'm replacing the seat regardless to give the bike straight lines. i just ordered my tank online and I'm waiting for it to arrive. Also are you planning on using rearsets?
hey jrscruiser
I have had a tough summer. Had to limit employees at my business and as a result, I am working more than ever these days!
I really havent done too much and am hoping to get going again once the snow flies and things slow down at work.
I am planning on using some type of rearset. Stock positioning is way too low and forward, and just not right for a cafe
