82 cb 650 battery not charging
maddrill24
Active Member
i feel like ive seen this post a million times no matter what bike. brand new battery and 3 days later im push starting it at my first stop, anywhere to look first??? i feel like these electrical systems can be a mind F**ck.????? and while im trying to fix the 2 problems i have. i recently bought the bike and the guy said he had to install a inline valve for the fuel. if you left it on it would flood. so the first time i rode it i left the fuel on for bout and hour parked and i had fuel leaked out of the exhaust! i was told maybe the diaphragm on the #2 carb is bad.???
Pull the generator cover and check brushes are not worn out.
Brush holder is bolted inside cover.
I don't think brushes are replaceable, you have to get complete thing.
Check all the wiring connectors and fuse panel (is that the one with fuses under cover on handlebar clamp?)
Check the rotor as well, you need to be getting 4.3 ohms across the rings. With a multimeter on the battery, and the engine running, gun the bike and see if the volts go up. if not, for sure it's the rotor, stator or brushes.
thanks much for the info. i looked into it a bit today. after reading the comments you all left i looked at the brushes, their all good. plenty left on them. cleaned the rotor rings. it did seem to look like it got way way way to hot at one time. some of the varnish was gone off the copper wire on the stator. the rotor stator and all just looked like it got super hot. i tested the ohms on the plug under the side cover those all read right. then i tested the rings on the rotor and they read 4.1 to 4.6 ohms. the clymers book says if it reads anything over .51 ohms the rotor has a break in it. soooooo im thinking at the least get a new rotor????
Yep, sounds like rotor is cooked.
Look for an aftermarket replacement, (rewind)
It should have much better quality insulation
ok for the record im very greatfull for the knowledge and info. and im not saying your wrong at all! but when i started looking for a new rotor all of them had very close ohm readings as mine. so i kind of got suspicious. the stator was just totally done. frayed wires and just in awful shape. so i replaced it. i did the test in the clymers book to check the reg/rec. and it came up bad. so i replaced it. everything is good now 14.7v at the battery at 4k rpm. i do have to say i tested the brand new reg/rec. and it read the same as the old one i replaced. dont quite get it but hey it all works great now. im not trying to "knock" anyone but more or less spread the info
That's the problem trying to fix things you can't see.
At least it's all working now.
I get the feeling Clymer may have some of the numbers wrong for electrical tests?
