I'll see what I can do. Even stripped down, it's still a heavy bike with a cruiser style v-twin.cosworth said:Needs more wheelies.
That took a little imagination. It's pretty hard to find a tank with a wide enough tunnel to fit over the Virago frame, but the Vulcan tank's tunnel is actually a little too wide. In the front, I welded new mounts in the tank tunnel and some "sliders" made from 3/8" chain links that are welded to the frame. In the rear, I welded another mounting tab to the tank, and a tab with a nut was welded to the new subframe mount. The tank is isolated from the frame with large rubber grommets at all three mounting points. I also welded a couple of "filler" plates at the front of the tank to take up some of the gap between tank and frame.zap2504 said:How hard was it to fit the '89 Kawasaki Vulcan 750 tank to the Virago backbone?
