83 CB650 Nighthawk cafe-ish first build.
Stunt318
Craigslist find, 83 and 85 CB650SC Nighthawk $800 bucks for both, couldnt pass it up, bought and picked up them that day.
Then the dismantle began almost immediately. Tore both bikes down to the frames. Broken in one pile, working, maybe working, repairable or condition unknown, in another pile.
Dismantled the 85s' motor first, to find a wonderful surprise....check out the pics, must have been sitting for a LONG time, but the trans is good. The 83s' motor is in much better shape at least the top end is but the trans is a mystery, doesnt shift smoothly if at all on occasion. At least I can build one good motor from 2. So first on the order list.... Engine rebuild kit. Ordered
Forks are also a little mysterious, Im not completely sure either the 83 or the 85 are working correctly the rebound feels funny, the slightest of grinding feel but there's no grinding sound if that makes sense.... no leaking either, not that Ive opened them yet, for all I know there's no fluid in them at all. Second on the order list Progressive Springs and seals, ordered. I also ordered the new bearings all around, why put the whole bike back together just to take it apart again for a $25 part.
I started the frame prep first. Cutting, grinding and sanding off all the not-gonna-be-used little tabs, wire holder thingies, weld spatter was all over the place from the factory. Took a good long look at the frame played with the tank and seat came up with a game plan and cut the back off. Designed and fab-ed up the rear loop. Currently only spot welded in, not sure Im perfectly happy. Gonna play with tank and different seat designs before making it permanent.
Picked up a 87 V65 the other day for $250. Only because I was dead set on doing a single shock conversion. But lately as Ive been working with the frame, Ive really fall in love with the dual rear shocks. But I will be using the rear wheel from the V65, and swing arm, the axle bolt is way thicker. AND I get rear disk brake vs the factory drum.. Lots of fabing to come.
Nighthawk front tire is a 19, 16 in the rear. the factory stance is just anti-cafe as it gets. This was most-likely not the ideal bike for a cafe style bike, but $800!!...
So I picked up the V65 for the 17inch rear, 18inch front. But the front shocks have different axles and are so bad on the V65, a little more than Im will to repair. Ill be keeping the 19 front.
19 front, 17 rear, not ideal but.. hopefully just the right tires will get her sitting right. So the wheels wont match.... I honestly believe the stance is more important.
Whats left, will be doing clip-ons which leaves a huge problem of the tank, its super wide at the front. Going to have to either narrow the tank in the front, make indents(really hate this idea) or find a different tank. Havent decided...
Rearsets.... OMG who knew there where so dam many. I know I want something idex-able with folding pegs and black, been shopping havent found anything if any of you have ideas that is not $500 bucks Im taking suggestions.
I was planning on a 4 into 1 exhaust but again fell in love with the look of the factory equip. the 85s is in great shape, chromes clean, no pitting, little to no rust and no dents.. A little clean up and I think it will work just fine.
Pics attached, this is where Im at.. I promised the wife this wouldnt get out of hand and last all summer so there is gonna be a lot of updates, my hope is a month, realistically that will be 3 months, so all summer.... lol.
So its been a while since Ive updated, but Ive been working on the bike just a little everyday almost. Came across a problem, and need some advice. In 2 of the galleys for the camshaft on the intake side, i have these really small scratches.
You can see them in the pics below. I inspected the camshaft thoroughly and it has no signs of uneven wear, scratches, or burns. I'm starting to think I must have made them myself during dis-assembly, but I was so careful, now Im not sure. If i run my fingers across it, I cant feel the scratch, or catch it with a finger nail. What do I do? Ive never come across damage like this before. Any ideas? leave it?
At first I wasn't planing to get this deep into the motor, but it was just too dirty. Looks like the previous owner ran it super rich on dirt. Its going to take FOREVER to get this thing running again.
Rebuilding the carbs now as well, just a cleaning really, they are in pretty good shape, they need to be pretty, not just work correctly. I'll be post pics of that work soon too.
Also started rebuilding the forks, waiting on seals to arrive. Brake caliper rebuild started too.
better do the tests on all the charging system components those bikes were plagued with charging problems rotor stator and reg/rectifier
or all of the above
Little update. Been doing a lot of detail work. What began as "lets get this cleaned up" turned into "might as well polish it".....
What a nightmare, turning 8 rusted, dirty, seized, oxidized carbs to 4 clean fully functioning carbs pics below show before and after, took way longer than I thought. Rebuild kit, replaced just about everything... Have a little more work putting it all back together, hopefully in a day or 2 they'll be ready to be mounted.
As for the valve cover I was going for a brushed aluminum look, pics below was the best I could do, I like it with a slight pattern..
Light clear coat for protection and good to go.
Got some work done today...
No small task to get calipers from black to Honda gold. there was a little run, so it'll have to be lightly sanded and sprayed again. And there are still 2 more to do...
And the carbs are completed.. What do you guys think.
