85 GPz750 Cafe' Build
CafeCruzer
So I picked this baby up and got straight to work... This is my second cafe build. I Fixed up a TX500 in 1993 --I wish I still had that bike...
Re: 85 GPz750 Build
Breaking it down
Re: 85 GPz750 Build
I degreased the engine and threw on some new paint before I found the broken shifter bearing
Re: 85 GPz750 Build
i ordered a bunch of LED's, resistors and diodes to fab up my TRON style lights. I'll post details as the parts come.
Re: 85 GPz750 Build
Last week I de-tabbed the frame and lopped off the tail.
Re: 85 GPz750 Build
I stripped the old tank and put it in an electrolysis bath but I couldn't get the rust to come out...
Re: 85 GPz750 Build
Did some work on the frame. Hit it with the wire brush on the grinder and then took the rest of the paint off with aircraft stripper. After a wash down with phosphoric acid she was ready for some self etching primer to stop surface rust. Then i bent some tube, welded in the hoop and some plates to go under the seat pan from my electrics.
Re: 85 GPz750 Build
Picked up a rearset and pegs from craigs... Ninja 250 stuff will work great after I fab up some new parts to mount them
Re: 85 GPz750 Build
I bought this GPz tank on 3bay. Slight surface rust inside which i can remove. No dents just dings and pretty decent paint. The bottom one is a shot of the '88 GPz550 paint scheme that I am contemplating (problem is, the decal set is like $170 and I only want the tank decal ):
Maybe you should mock up the rear suspension. Looks like a rear tire conflict with that pan. Looking good otherwise. Maybe you could find just the Kawasaki lettering graphic and paint the background colors. The background paint would be easy to do, and probably you can find just the simple "KAWASAKI" decal pretty cheap.
Sage advice jpmobious...
I was looking at this fella's bike and he seems to have the same elevations:
http://thebikeshed.cc/forums/topic/gpz750-unitrak-based-street-tracker-work-in-progress/
Alas, I will still be taking your advice and mocking it up!
As-far-as graphics, I was going to go with a black tank and use a lime green, vinyl KAWASAKI decal under some clear coat. I do like the idea of recreating the 88 paint and slapping on a KAWASAKI decal though...
CafeCruzer said:
Thanks all for the comments and advice!
Im actually kinda stoked to mock it up and check now... 8)
good on ya ! you'll need to pull the spring off the shock or at least back the preload as far off as you can then ratchet strap it down against the bottom bumper....to know what clearance you need
And as XB has said many, many, MANY times before, you'll need a minimum of 1" clearance at full bottom-out
Mocked up the bike to check a few things. Even with the ZR750 mono shock I'm sticking with the specs that call for 104mm of rear travel. I measured 82mm with the current set up. So, I will be relocating the rear pan up 2cm to allow for clearance. Thanks to all for your tips on that one.
While I have the forks in, I cut the tubes down 7/8" and sprayed some Blaster PB on the cap bolts. After a few taps with the ball peen and some bruised elbows, those baby are loose --ready for the fork over hall.
So far so good.
Hey Cruzer-
If you adjust the rear axle eccentrics so the axle is at the bottom, that'll give you more room.
Also, are you planning to just move the sheet metal from the bottom of the frame hoop to the top? It looks like the hoop will allow the tire to move up inside it, so you could keep the hoop as is, if you like it that way. You could even dome the pan if you need even more room.
-Sherm
Sherm,
Dude, you are mindreader!
I was eyeballing the eccentrics as I sat there staring at the mock-up like a mental patient... I am keeping the hoop intact. The doming is a good idea. I have been debating whether to cut the pan out completely and mount it on top, or just carve out the area as needed. I think relocating the entire pan may be overkill, it just depends on how much wiggle room I have in there and how much I am willing to re-fabricate...
Rotated the eccentrics around (allowing for a similar chain tension) and I gained 33mm! The clearance under the pan now measures out at 115mm which is well past the 104mm and even allows a little more wiggle room. I looks like I can leave the pan intact.
