91 cb 750 mono shock question
kaptain27
Im trying to fit a swing arm off of a 2001 yamaha r6 , i think new bearings at a different size would solve the problem, but I'm not having any luck finding the sizes I need, any help would be greatly appreciated.
I don't know if this will help you but take it for what it's worth. There are lots of bearing sources out there, but I do a bunch of my basic research on eBay and Amazon. Lots to be learned there if you are patient and diligent. I swapped out to a 500 Ninja swing arm on my old CL360. The original roller bearings were 22mm X 28mm X 20mm (inside dia X outside dia X width) but the swinger had to be narrowed a bit and the bearing AND seal made things tight by one or two mm. I did the research and was able to order a 22mm X 28mm X 16mm. I lucked out because the original swing arm pivot bolt from my Honda was the same diameter (22mm) as the one from the Kawasaki. Hope this helps.
