904cafe
CB200 carb questions...
several questions concerning my carbs....
i purchased a set of carb kits and they came with very small rubber o-rings... i don't know where they go? theyre too big to fit into the air mix screw hole and i don't remember seeing a o-ring when disassembling them. and another thing with the main jet... should it not seat all the way down into the carb? should you still be able to see about half of the threading?
second... my throttle is sticking... and only after i reassembled the carbs witht the new kits? i checked the springs they seem to be free and not caught up. the left carb seems to stick more than the right but it could just be me. maybe i just need to slap some grease on the throttle handle and where the cable connects?
third... i just put on a CL175 exhaust (onto a CB200) and the short side (left cylinder) seems to have more exhaust pressure coming out of the end and seemed to warm up a lot faster when idling.... could this just be because its shorter or is this a fuel mixture issue and its just running lean? (prior to carb rebuild and CL pipes both cyclinders were running rich).
ANY ideas on any of these will help me in the right direction... im a NEWB at all this bike stuff still so bare with me... THANKS!!!
