I recently bought an Accel 3ohm Dual Output Coil from another DTT member. The 1976 KZ400 that I am going to use it on uses a 4ohm coil. According to http://chrislawson.net/kz/repairmaint.shtml under the electrical system heading, I will need a ballast resistor. Can I just buy a ballast resistor that is about 1 ohm like this one,
http://cgi.ebay.com/ebaymotors/MSD-Ignition-8214-Ballast-Resistor-0-8-Ohm_W0QQcmdZViewItemQQhashZitem563a875bd4QQitemZ370349136852QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
or do I need to do some calculation to figure out the correct resistance of the ballast resistor. Also do you guys think this is even necessary. And do I just connect it in series right before the power cable in to the coil. What exactly does a ballast resistor even do, protect the coil from voltage spikes, why do different coils have different primary resistances?
