Tad
Well I've been in the garage again. This time it was to make a under tray so I could do away with the shaped plastic mud guard in front of rear wheel. The tray is made out of thin ali sheeting, I do have to remove it to paint airbox side. While it's off I'll do some measuring and post it with a drawing should anyone else want to make one.
It is bolted by two 6mm bolts on the frame under the seat (holes in frame are already there) and two 6mm bolts at the bottom where the rubber mountings for plastic guard are. I left rubbers in and used nylock nuts. I also used some rubber beading to cover up sharp edge.
1st photo shows before and others show after.
