Acewell rpm issue
cb550k
Hi everyone this is my first post on this site. I have a 1978 cb550k. I recently bought an acewell 2853 and I'm having trouble wiring the rpm. I tried wrapping the tach cable around the spark plug wires and I'm not getting an rpm signal. Is there any other place to connect it to?
Thank you everyone in advance.
If the coils have a 12v lead you can go straight off of that. How many wraps around the coil lead did you do ?
Cheers
Steve
Sent from my GT-I9300 using Tapatalk 2
Re: Re: Acewell rpm issue
Cheers
Steve
I wrapped it around 4 to 5 times. I'm not picking up signal. Is there something wrong with what I'm doing? At that time I had just washed my hands and we're a bit wet. This can't be the reason can it?
I think that you need closer to ten wraps or so.
Ok stupid question. Should I be stripping the tach wire so that it's bare wire before I wrap it? I tried wrapping it around the coil over 10 without stripping it and I'm not picking up signal.
Absolutly not. Do not in any way remove material from the coil leads. Are you sure everything else is working correctly?
The gauge is recieving power and properly grounded?
The tach feed wire is undamaged?
Does the speedo work?
Is the coil that you're trying to read functioning properly?
May all sound stupid, but sometimes its the obvious that gets forgotten.
Yeah I understand I made sure that all were functioning.
The gauge is receiving power and it is grounded. I will try putting the ground straight to the battery. The tach feed wire I spliced (yellow) but just enough to wrap it around 4 times and the rest were just wrapped without splicing the yellow wire. Should I splice the yellow wire in case the cover was getting on the way? I haven't hooked up the speedo yet. I'm trying to figure this tach first before jumping on the speedo. I did do a spark plug test on all coils and confirmed that it was providing spark on each one.
It was the tach feed wire I was splicing not the coil lead. Sorry I shouldve been more clear.
Can you take some pictures of what you've done with the yellow tach feed? I thought that the Acewell came with a wire to wrap around the sparkplug wire that you could plug into the yellow lead.
Re: Re: Re: Acewell rpm issue
That wire is then connected to the gauge. The part where I spliced the yellow is the part of the wire I used to wrap around the coil.
Ha! "Splice" is when you tie two wires together. You have stripped the yellow wire. :)
So: I would suggest taking another piece of wire, wrapping it around your plug wire a bunch of times, and then tying it to the yellow wire. Do not strip the new wire. Give that a shot and see if it works.
Stripped! Lol. Sorry. I'm new to all this. I'll give that shot and will report back. Hopefully it works!
I tried wrapping a new wire tied it to the yellow wire and still no signal. This coil does spark for sure. I forgot to mention. I'm running a dyna s ignition on the bike. Is it possible to pick up an rpm signal from there? If so which wire do I pick it up from?
Coils need to be tighter. Like so:
When you're done:
Ignore the cutaway braiding, and the 'copper tape' bit. Running the wire out will reduce interference.
SLow down a moment. That wrap is unlikely to work. I'm no electrical engineer, but my understanding is that the tach tyopically needs one to 3 turns around the plug wire and they should be nice and tight. I think that crossing those over like that cancels out the signal but I could be wrong about that.
With Scitsu race tachs, anything more than a couple of turns usually results in chaos. On those, we often lay about 1-2" straight along the plug lead and tape it in place and that's enough.
Some tachos prefer to be connected to the trigger side of the coil. Trail tech works like that. I strip 1/4" off the end of the signal wire and connect it to the coil connection that goes to the dyna - not the switched 12v side of the coil. Acewlll instructions say the same thing. They say 2-5 turns OR connect to the coil where it connects to the dyna.
Ok I've tried wrapping it around the plug wires nice and tight. I went from 3 wraps all the way to 12 wraps. Still did not get signal. I will try and connect it off the dyna. Question. On the dyna there is 2 wires for cylinders 1 and 4 and another 2 wires for cylinders 2 3. Does it which cylinders I use? Do you have any idea which wires I should connect the rpm to?
Here are pictures.
Connect it to one of the coils - doesn't matter which, but make sure it's the Dyna side of the coil - not the power side.
I'm not sure you want to be doing that.
Keep in mind, this wire is simply sensing the voltage in the spark plug wire - same as with a timing light.
Connecting it to an actual 12v power source is likely going to do something bad to the gauge.
I'm not sure how else to pick up the rpm signal. I'll be patient and wait to see if there is an alternative.
