adding an LED bulb to the headlight
vandito.cb
i want to add an LED to the inside of my headlight to serve as a...parking light, so to speak. my headlight switch has a position to kill the power to the headlight so, sunlight permitting, i'd like to keep just an LED going in there. it would be wired separate from the hi/lo, of course.
anyway, my question is what would be the best approach to doing this? i know i'll be drilling into the shell, but should it be sealed simply by adding a grommet to the socket or should hot glue (hoping i'll need to replace the bulb as sparingly as possible) be added to the outside edge?
my main concerns are moisture and losing the bulb inside the light and having to fish it out.
the first picture (from DCC's website) is of a headlight with the exact type of bulb i'm referring to and the other picture is what i suppose would work for what i'm looking to do.
any input would be greatly appreciated.
Assuming you're not using a sealed beam headlight, it should be pretty simple. Make sure you can access the reflector without too much difficulty and you should be good to go.
A rubber washer or grommet should be fine. You shouldn't get too much water in your headlight bucket. If you are worried about it I would recommend sealing it with silicon (like silicone caulk). The headlight bulb might melt hot glue.
And be aware, it may melt the LED as well.
I have a similar headlight (with the extra bulb) on my DS7. I was going to do the same, and haven't wired it up yet, but I was cautioned about it possibly melting an LED bulb back when I bought it a few years ago. Maybe Sonreir can chime in on that ;)
Possible.
Higher wattage bulb means more heat.
You probably won't have any issues with any bulbs, but 65W is definitely going to be more likely than 35W.
You can always swap over to an LED bulb. We have 20W ones that are very bright.
