Adding H4 bulb, need help.
CBPayne
I'm making a new wire harness for my bike and having a little trouble. I have a H4 headlight that I don't know how much power it consumes. I'm doing a bare bones wiring and wanted to know if I should use a separate fuse for just the headlight compared to using one fuse for headlight, taillight, and gauge lights. Also do I need a relay for an H4 headlight? Last question, in Sonreir's electrical 101 it says use the smallest wire in your circuit. So my headlight has three 16g wire coming out and therefore I would use 7 amp blade? I'm pretty sure if I ran headlight, taillight, and gauge light on one fuse I would have to go heavier on the fuses, or just run it separate.
If you are going to split them, head and tail go on separate 10A fuses. If all run through one fuse, use a 20A. Going off the "chopper" simplified diagram proven to work for LS650s, which come stock with H4 headlight bulb, no headlight relay, and a grand total of 2 20A fuses for the entire stock machine...
I use a 15 A self-resetting circuit breaker dedicated to the headlight circuit. That will handle dual H4 headlights, even.
10 seconds of Googling will find you the specs on H4 bulbs. 55W low beam, and 65 W high beam.
I prefer to use a relay rather than run all that power through the handlebar switch, (which causes some voltage drop.) I also prefer to use 14 ga or 12 ga wire for the headlight circuit to minimize voltage drop.
Hey thanks Scruffy and Alpha Dog. I was just stating that I didn't know the power consumption of H4 bulb. I wrote this post around 2am, well I wasn't sober. I'm going by a bare bones wiring diagram this guy Dan did. For the most part I will be able to use it. He went from the four fuse in the diagram to three. He isn't using a lithium battery like I am and he doesn't have led indicators or a H4 bulb. The first one is the ignition side and the other is lights.
Battery choice is not relevant. It is just a reservoir for power. It's the charging system that determines how much power you can use. If you use more power than the charging system generates, then your battery will go dead, no matter how big its capacity is. When I went to dual H4 headlights on my GS450, I had to upgrade my charging system to handle the extra load.
Using LED turn signals only saves a little power, as they are only used intermittently. They require an electronic flasher. Some people will use a load resistor to make the old fashioned thermal flasher work, but then you don't get the power savings of the LED's. LED tail/brake light DOES save a significant amount of power, because it runs all the time. Also, the brake light being LED saves significant power at a time when your charging system is producing minimal power. (When stopped and idling.)
You don't HAVE to use a relay for headlights, but I like to because you get more power to the headlight. I also like to use a relay for the horn. Makes a horn MUCH louder.
Just to correct ADC (it inspires ADC to replying with witty and urbane comments), H4 refers to the mounting system of the light, not the wattage. A stock Automotive H4 light is usually 55W low, 60W high beam.
HOWEVER, I have an H4 bulb on my CB360 that is 35W/35W. in addition, you can get up to 85W/100W bulbs.
Most are Halogen, but there are other "chemistry's" like Xenon, that offer less light for the same wattage with blue tinting. In addition, some claim to be Xenon, but are really just blue tinted.
So H4 = Mounting.
Standard Wattage = 55/60W
Lots of other wattages available including 55/65 and others.
Also, here's a nice little PDF on the numbering. You may of noticed that there are HB2 and 9003 designations on H4 bulbs too...This article talks about that.
http://candlepowerinc.com/pdfs/H4_9003.pdf
good info i never had that H4 was the mounting, thumbs up !
on another note a common miss-conception about "light bulbs"
thay are not really "light" bulbs at all, they are dark suckers and eventually they fill up 8)
mydlyfkryzis said:
So H4 = Mounting.
Aw jeez, I typed 55/65W.
That was a typo. Yeah, that's the ticket. A typo.
That's my story and I'm sticking to it...
I was actually going to say you made a typo, but then you would not have any reaction...no fun in that.. 8)
o1marc said:
H4 bulbs can be gotten in wattages any where from 30 to 150
That's for Halogen..there are LED and others that extend that range down....I haven;t seen any H4 LED bulbs that are adequate yet, but that day is coming...
The only reason I was wanting to know the wattage was cause I don't know anything about wiring in relays. Wanted to know if there was certain ones I needed for my light. I bought a H4 relay harness from eastern beaver. I still dont know how to wire up a relay, but I'm going to have to learn for my single horn harness.
