Advice - Kick Start Shaft
expelled
Active Member
I bought a bike from a friend and before I even rode it I tore it apart, had the engine rebuilt (top end) and am in the process of rebuilding the bike with new and freshly powdercoated parts... well come to find out the kickstarter shaft is broken? I find this out after getting the engine back (another friend works at a machine shop and did the work for me).. it still have the starter etc but do I really want to run a bike without the kickstart? and more importantly, is it really worth cracking the case (isn't that what I'd have to do?) to install a replacement?
thanks in advance!
First off, what bike?
Regardless, the case will need opened to swap the kicker shaft. Be sure the clutch isn't somehow stuck - you can't kickstart older honda's with the clutch in. I would say you may as well do the shaft now while the motor is apart and out of the frame. And remember, you can always bumpstart too.
Big Rich,
its a 76 cb200t.. I just got the engine back and it is put together already.. still out of the frame though. I'll have to find more info on cracking the case.. I have never done it before and it seems quite daunting..
thanks for the info!
ah, a 200. Diesel 540 will probably be able to help you out - he's been into one fairly recently.
If it's anything like a 175, it shouldnt be too hard to split them. It's also not to hard to bump start them either......
It's easy, but not fun. With ignition on and kill switch off, put the bike in 2nd gear. Squeeze the clutch and start running. Let the clutch out while playing with the throttle. And be ready to either squeeze the clutch back in or hop on the bike.......
It's much more useful on a race bike - not nearly as "cool" every time you need to start the bike (especially during tuning).
