Aftermarket starter button, no kill switch
sbelshe
Great forum, tons of help. First post
I've been tearing down and rebuilding my '72 CB350's front end and removing and streamlining alot of my components. The factory right side controls are gone, so I no longer have a kill switch. I have connected the black/white and black wires coming our fo the kill switch to complete the loop and am able to fire the bike using the kick start.
Living in the midwest, the bike can easily get cold so I didn't want to rely strictly on the kick start. I bought a 2 wire ignition button on amazon (http://www.amazon.com/BUTTON-MOMENTARY-CUSTOM-SWITCH-STARTER/dp/B007RORPX2/ref=sr_1_4?ie=UTF8&qid=1357854021&sr=8-4&keywords=starter+button+harley). Basically just a standard momentary switch but has a style that fits the bike.
Problem is, I'm not quite sure how to wire this thing up. Obviously one wire will go to the red/yellow wire that originally went to the ignition switch, should the other wire go to ground?
Thanks in advance.
yup on my cb350 f the black wire goes to ground also aftermarket switches havent got a kill switch wires together to complete circuit use ignition to turn off bike seems fine for now good luck with the build mate
So in your case, you wired the black/white wire to the solide black wire (technically into the series of black wires within the harness), then on your ignition took one wire to the red/yellow wire and the other to ground, correct?
The other wire just goes to ground. If you look at the circuit in the diagram, if you ground the yellow/red wire, it triggers the starter. In the stock controls, the button just grounds the y/r wire to the handlebars.
Sorry mate didnt make myself clear the solid black wire and black/white wire joined together to overide the fact there is no kill switch the red/yellow goes to the starter button black to ground when switch is pressed with ignition on the startermotor starts the engine the ignition turns off the engine instead of a kill switch hope this makes more sense mate will try find diagramn to post you
Thanks for the feedback fellas. I have a good wiring diagram here and can understand most of it, but that isn't always enough unfortunately.
At this point I have black/white connected to black which should make the coils hot with the key on. I have my two wire starter button with one wire connected to yellow/red and the other connected to green to ground it. When i hit the switch, I get a single click from the starter solenoid. I think the button is wired right but I may have cooked the starter solenoid by mis-wiring the button once before posting here. At least that's my guess. Open to suggestions there as well.
I have also been reading alot about the yellow and yellow/white wires from the harness that were in the headlight. I know they were a part of the alternator auxiliary charging system. It seems most people just connect the two together and I've read that this will engage the charging system all the time. Can anyone with experience confirm that?
Everyone has been a big help so far, thank alot.
