K&N seem to be one of the best. They are a little pricey but well worth it in the long run. You also want to get filters that do not cover vital vacuum ports on the carbs.
There are various ports on some of the intake sides of the inside of the carb. If the filter is offset enough to block a port if could give you poor performance in a certain rpm range (idle, mid, high). The fuel/air doesn't get mixed properly and you end up with problems.
You aint lying,Iv been working on bikes for 15 years mostly modern ones.And couldnt wait to get a 70s bike,I figured it would be so simple.Now i got to learn to be a retro mechanic,I love it though. THANKS
