AllBalls Bearings
o1marc
Over 1,000 Posts
Is this the worst site to navigate or what? Are you just suppose to flip through 132 pages of bearings till you find what you want. There's no index or search function. It's all in numerical order by kit number but not by specific bike and it's all random.
http://allballsbearings.com/index22.htm
I may have been on the wrong site. AllBallsRacing.com was probably where I needed to be and found it easier to navigate.
looks like its just an index for this site. http://www.vxb.com/ All the check out links take you there.
Go to All balls racing instead. They'll have what you're looking for.
http://www.allballsracing.com/
www.allballsracing.com and then just choose your bike. Some models arenot actually listed but they have bearings that fit them. So if you dont see what you have, try to ifnd the bearing size and I'm sure they have it.
Captmilk76 said:
I got mine on eBay
Sent from my SCH-I605 using Tapatalk 2
You got what on Ebay? You can't get it on Ebay without knowing what it is you need (part #)
No... Search "bearings CB750" (or whatever bike you need them for) on ebay. The AllBalls kits will be listed. Both wheel and steering stem. You're still just buying from them, so it doesn't really matter. That said, there are other options available on EBay for most bikes. I got a set of high quality steering stem bearings from a French company (who's name slips my mind at the moment) for a fewbucks cheaper than AllBalls awhile back.
I didn't know how to search Ebay for a CB400f to CBR600f1 fork conversion kit. Can you find it on Ebay?
Standard neck and wheel bearing can be sourced locally for almost always less than ebay. All you need are the 3 dimensions. Seals are another question although with the old part # they are easily sourced locally.
Re: Re: AllBalls Bearings
That application is less likely to be listed as such, natch. :)
Sometimes the kits are cheaper on amazon then ebay, don't forget to check there too. solid bearings though.
At what point in your original post did you mention that you needed a conversion kit? Oh, you didn't. So knock off the bullshit. I was actually attempting to help you (for some stupid reason) yet again.
Last time I do that though.
At what point did you feel the need to help me find something I didn't ask for. You made an assumption on what I needed after I merely asked about navigating the first website. Others said "I got mine on Ebay." But didn't say what they got there so I felt the need to inform the masses of what it was I needed. But again I'm the asshole here , right. You have proven again to me what a douche bag you are.
If you read my OP you will see that the only question asked was whether that site was the hardest to navigate. I edited the post to show I found the correct site and that no response was needed to the post at that point. The first 2 replies were from members directing me to the site I had already acknowledged finding.
Amazon did not list the kits I need. Thank you.
kopcicle said:
Problem is I also have no problem calling an inept time waster just that , a waste of time . Guess I'll have to work on that .
..laughing at you , not with you
~kop
<---still a dick
