SONICJK
Reminds me of...me No, I'm sure of it. I hate him
Please.
Okay so rebuilt the cb350.
Carbs are clean
Spark is good
Compression is good
Static Timing is perfect
Point gap is good
Valves are adjusted
So my problem is this:
The damn thing won't run.
If I let it sit for a while it starts right up and runs okay for about 30 seconds. Then it goes to the point where I have to run it at full throttle to keep It running and it only runs on one cylinder until
It won't run anymore. If I let it sit for 15 minutes or so this will start all over.
I cannot figure out the problem.
The only other thing I can think of is float height, but I've adjusted it several times and when I pull the carbs there seems to be a good bit of fuel in there.
I have square floats from Sirius consolidated and am unsure what point to use as reference for measuring.
I painted my carbs recently with por15. I scraped it off of the vents to no avail.
So someone please give me some insight into what may be going on!
Carbs are clean
Spark is good
Compression is good
Point gap is good
Valves are adjusted
