Alternative or Aftermarket Headlights
synapblink
Hello everyone. I searched on the forum, but haven't found the answer.
I have a 1974 Honda CB200 with a broken headlight unit. The bulb is dim, it has no lens, the headlight bucket is slightly cracked, and the mounting bracket is bent. I was wondering if there is an aftermarket headlight unit with brackets that fit for my bike model.
Pretty much all the older Hondas use the same headlights. If you are looking for a brand new replacement, check out www.MikesXS.com.
Just don't try to use an H4 bulb, the charging system won't be able to handle it.
