sxecafe said:
On a 12v battery (or any battery for that matter), what does the amp hours actually mean/translate to?
How many will I need in order to run a Dynatek Ignition system, Acewell speedo, a regular headlight and LED tail and turn indicators.
I'm a wiring nu-b so any information would be sweet!
Hi here's something that will help you out.
I give credit to Zonda:
"Bouncer,
The battery came about when i wanted to use a different battery other than the lead/acid ones. did some research and found that the majority of rechargeable batteries could not stand up to the constant drain and recharge of the bike (or no guarantee).
The lead/acid battery is still the best for the bike as it can dump huge amps quickly and has a fast recharge. in short it can give a lot very quickly and has a small recovery cycle...
So what to use? the Optima range or batteries uses a spiral wound lead/tin battery that has a low discharge rate, ie it can hold it's voltage for a long time, so it is ideal for emergency generators etc. but its down site is that it will not dump its power fast, to start an engine it dumps it power slowly.
This is what i used, and as the batteries are available in "D" size 2 volt 2.5 amp. I would need to get six and wire them in series.
OK series and parallel, (parallel) if you have six 2 volt 2.5 amp batteries and wired the - poles together and the + poles together (like power poles) then you would have 2 volts and the potential of 18 amps..ok?
Now if you got the same batteries and wired them from - to +(ie connected the positive terminal to the negative terminal and +-+-+-+ etc) and continued, the first battery would have a spare - terminal and the last battery would have a +...got that... you would have 12 volts (2 volts x 6) and 18 amps (2.5 amps x 6)
Hows the head?? now lets talk amp hours, Ha Ha, a 12 volt battery with 1 amp hr can hold the drain of a lamp (etc) that drains 12 volt and 1 amp for 1 hr before the voltage starts to drop.
so in theory a 12 volt 18 amp hr battery can sustain 12 volts and 18 amps for 1 hr. or 12 volts and 36 amp for 1/2 hr before the voltage starts to drop.
or think of it this way lets say you have a 12 volt bike, and this bike draws 5 amps while it's is running, now if the motor ran for a whole hour the bike would have drawn 5 amps in total for that hour, or 5 amp hours (5Ah), and if it ran like this for 24 hours it would have drawn and consumed 120 Amp-hours in total, 5Ah x 24h = 120Ah.
Ok this doesn't help us much as we have volts and watts. so how do you convert watts to amps and how can we use this to judge how big a battery we need.
You simply take the stated Watts, and divide that by the Voltage and this gives you the Amps that the item will draw
So lets say for example you have a 55 Watt light globe (like the type you find in your head light) and divide this 55W by the 12V that is used to power it and you end up with 4.5A at 12V...good to know as this is the size fuse you will need...4.5 amps
so if you add up all the watts from your bike you will know how many amps you will need to power it.
coils 35w
headlight 55w
tail light 25w
brake light 8w
tach/speedo 2 x 3w
indicators 2 x 8w
to start the bike without the starter you will need enough amps just to power the coils.....35w or 35w / 12 volts ...3 amps, so a 12 volt 3 amp hour battery would be enough to run the bike....in theory.
ok then we have a total of 137w divided by 12volts.......11.41 amps just to run the bike......at night...
to start the bike we need 1440w for the starter motor and 35w for the coils...1475w divided by 12....123 amps for a very short time, lets say it takes 5 seconds to start the bike and we have 12 amp hr battery, so it can deliver 12 amps for 1 hr or 12 amps 3600 seconds (1 hr is 3600 seconds)...still with me then we can divide 3600 seconds by 1475 amps and find that the battery can deliver 1475 amps for 2.5 seconds BEFOR it starts draining the battery....so as the battery starts to drain the math needs to be done again at 11 volts and 10 volts.....I hope that i have not confused you.....we notice this as we try to start the bike with the starter motor and it gets weaker and weaker untill no volts/amps are left...
Now just a note this is all well and good if you only run a battery......as our bikes have an alternator/AC generator this provides the necessary amps to run the bike and recharge the battery... my CB450 SHOULD produce around 13.8 volts and 8 amps, which i doesn't and as i draw around 14 amps just riding it (lights on) battery drains down weekly....this is one thing that i'm fixing for this bike. my local elect wizzard is rewinding the AC generator to produce over 20 amps
If i have got this wrong could someone correct me, it's been a while since i taught elect theory...
Rod from oz"
