Great idea man!Tune-A-Fish said:Hah! parts sharing is something that is lacking (openly) we have a sell thread, but maybe an ask offer thread is in order as well.
I would have to say I'm 109% sure. Completely disabled, ultrasonic cleaned, soda blasted (I know that does nothing to clean passages) then multiple cleanings with carb cleaner spray/ compressed air through all passages. Same treatment with all the brass minus the soda. I didn't use the rebuild kit brass as the Jets were way of factory specs (112 mains I think) as opposed to 92.5.teazer said:Are you 110% sure that the carbs are really, really, really clean?
There are a couple of tiny little holes that the air/fuel mix sprays out of at idle and they are usually plugged or partially plugged. Technically they are the pilot outlet and the bypass but who's counting?
Tune-A-Fish said:Hold the drain tubes up and verify the bowls are in fact full when running, sounds like starvation to me??
Tune-A-Fish said:Pilots need to be closer to 27-30 and seriously would go 28-30 to start I just went and looked through my notes on the 550 and had the same issue and increased 5 sizes over stock before getting a good 1100 idle then did chops to dial mains.
hurco550 said:good deal. thanks man. you happen to know your elevation? Ill grab some pilots and some rich mains and chop it down. It wouldn't be so bad if that dang air box wasn't such a pita to get on and off..... lol
hurco550 said:google says im 981 here, but im taking the bike down to Hendersonville nc for meltdown... its 2150 lol dang...
Tune-A-Fish said:Yeah it will be okay, bring a set of plugs but doubt you will foul out
teazer said:When you pull the carbs to fit new pilot jets, please take a moment to be 111% sure that the pilot jet outlets are clear and flowing the same on both sides.
I'm no guru. Just passing on what I found on carbs over the years. I had a set yesterday from a 750 that looked clean and after they were fully cleaned, when I tried to blast I found that the flow through those tiny passages were very different from one to another. The other PIA on many mikuni carbs is the tiny starter jet which lives at the bottom of a deep hole in the bowl and like all trolls, it loves to cause trouble.hurco550 said:Absolutely will man. When the two stroke guru gives you advice, you take the advice!!
Thanks Teazer
