Another cb 360t, but with a sexy twist.
OK.... so onto the rear cowl... I started with a wire frame to complement the tank.
Ok i started filling out the rear cowl with cardboard templates
is that a CJ motor ?...(5 speed w no electric start)
you better look into the battery you want now. that rear cowl looks pretty small. if you intend to stuff it in there. otherwise...yes, an awesome design.
Im already a step ahead... I took the starter out, I was able to fire up the engine and to kick it over was such a breeze that I decided to take out the starter. I got a plug from a guy from the forums.
I also purchased a solid state 4 cell battery that fits with lots of room to spare underneath the cowl.
Is that one of crazypj's plugs? I need to send him some money.
Your riding position looks really cramped and the seat too short and too far forward. I know you're going for a certain aesthetic here but I thought you should know the ergonomic aren't that great. Maybe change footpeg location?
I'm thinking it won't be so bad once she fills everything in. It's not made for highway trips of a thousand miles, it's a 360. That being said, don't be afraid of adjusting your foot pegs/grips/seat mounting point after it's all said and done. Nothing worse than building everything and having it look perfect and then it being so uncomfortable that you can't even ride it.
I have to agree here. I had a 350 with that same position and its not terrible....until you set one up right and it's a whole different ballgame.
I'd bring the foot-pegs up and forward a bit. That way your knees are gripping the tank instead of the cylinder heads (ouch) to me it's nice to have that little extra stability.
How I missed Rich ard's face palm is beyond me . I'm he resident grouch and sometimes Kowolski wizard here . I double as an unrepentant dirty old man and occasional XS650 builder . If carburettor or ignition make you crazy give me a shout . Other than that there are others here much more talented with the 360 specifically .
~kop
Re: Re: Another cb 360t, but with a sexy twist.
Agreed on all points...
As to your riding position, you might look at pics of horse jockeys - check out where their feet sit. At your height the seating position makes sense to me.
For me this position is comfortable, The picture was also taken when i was casually sitting on it... I was just making sure my butt would fit in the seat. The knee position, I agree might be close to the head, however if it was a stock tank it would be a perfect knee position. Also I am hoping to get this baby road savvy soon so I can check out that position in action before i paint the frame or do anything final.
What do you mean by solid state battery? You mean like a lithium ion?
http://www.revzilla.com/motorcycle/ballistic-performance-4-cell-evo2-battery
Ballistic battery it is lithium, but it solid state mean it isn't an lead-acid wet mixture. That way I can mount it sideways or upside down or diagonal and it wont drip acid.
Sorry for the confusion... the term "solid state" usually refers to electronics with no mechanical components.
That said, I don't recommend using a LI-ION battery unless you plan to upgrade your charging system. Stock regulator can allow up to 17V at redline and that will cook a lithium ion battery in no time.
...which you can do on the cheap:
http://www.hondatwins.net/forum/viewtopic.php?f=46&t=14530&sid=241fa727a3ac600ace7787a9e4b85fd0
