Hey all,
Current set up:
All stock CB 360 with 1k miles, bench synced VM30's w/ Mikuni manifolds to UNI pods
Jetting:
Main- 135
Pilot- 40
Needle- 6F5, 2 or 3 clip
Needle jet- 176 P8
Slide- 3.0
Air jet- 2.0
Air screw- variable
At sea level, 75f and kind of humid
Symptoms:
Will only start/run choked with throttle slightly cracked. I can give it more throttle but sounds a bit bogged and will only rev to 4k. Will die w/out throttle. Running a bit rough, left side is not firing properly, which is new but not sure if related. Idled great and was rideable-ish w/ above setup and 159 P5 needle jet. I would guess that it's rich w/ the 40 pilot and the 176 needle jet but the need for choke and throttle seems to refute that. I can't get a read on plugs.
Any input?
Current set up:
Jetting:
Main- 135
Pilot- 40
Needle jet- 176 P8
Slide- 3.0
Air jet- 2.0
Air screw- variable
Symptoms:
Any input?
