Another kick at a rebuild
I don't know if it's gotten around this forum or not, but there is a magic cure for restoring rubber parts like manifold boots. It's a 70% xylene to 30% wintergreen oil solution. The xylene is a solvent availible at most any home improvement or hardware store. And the wintergreen oil can be purchased at most drugstores. Just ask at the counter cause when I got some they kept it in the back with the scripts.
Just mix the solution in a glass jar or somethng with a lid, the solution evaporates fairly quick so you don't want to leave it open. Just place your rubber part(s) in the solution and let it soak for 12-24 hrs. The parts will swell in the solution, but don't worry, once they are out and the xylene evaporates they will return to normal and they will be soft and pliable like brand new. That should help make installation easier and help avoid cracking.
I used a mason jar and just did one manifold boot at a time on my 350 and 450 and it works fantastic!! They even smell minty-fresh when done.
Good luck.
And Canuck, thanks for the props. The new seat and the whole bike look kickass.
-Woody
colpumpkinnuts said:
I've got one. The same thing happened to my intake boots. I eventually got different ones off ebay. The one I've got that you can have is in rough shape but I don't think it has any leaks. I put some hightemp silicon around it just to be sure. PM me if you're interested.
Canuck your bike looks great!!! Hope you get your electrical sorted out quickly so we can see the finished project!!!!!
Nice improvement on the seat. I like the stitching, sort of adds a dimension to the whole tail and tank section. Looks sweet!
Man. Your bike turned out really nice, well done. I don't think I'd change anything as it stands now except for some form of rear-set.
Oh-Mah-Gawd! That really looks great!
I was wondering how you were doing all the electronics/wiring. Are you using the stock wiring? starting over? Sorry if I missed it. Also, how are you hiding all the wires? looking for suggestions.
i'd like to know what you did with the old seat~!!!! or, in other words... ya wanna pass it on?
Ah, sorry Mate. I sent it to a fellow down in San Fran. I'm having troubles shipping stuff at the moment anyway. lol. I was supposed to ship out a clubman bar to Loco Leon but I can't seem to get my arse to the post office in time. As for all the stuff you can't see I twisted it around abit. I kept the seat pan mostly stock. I shaved a bit to allow for the fairing and shortened it for the larger tank but the mounts are still the same. I then mounted the battery in the traditional place as well as the rectifier, fuse box, and solenoid. As a result, when you remove the seat (as you normally would on the 400) all the electronics and battery come with it. I put new connectors to allow for simple removable should I find I need to charge it or work on the sparky stuff.
I had a crazy idea today. I've been looking at the filter pods. Not happy with them. I really like velocity stacks but I thought rather than buy them, why not make them? I placed an order today for a flare tool that will flare 2 inch copper (type L). The rough measurements are 2 1/8. Same ballpark size of 2 inch copper (2 inch I.D. 2 3/16 O.D.) Figured I'd give it a go. I have some carbs that need detailing and rebuilding. I'll post some pics later. Possibly going out to the folks place on Weds or Thurs to give the wiring harness a go. Maybe some pics then I really like the vids everyone has been placing on there own blogs. The sweet sound of those engines running is music to my ears.
Peace.
Hehe.. no.. rehab is for quitters.... no offence to any AA members..
So.. following up on that idea. I need you to use your imagination for a moment.
I took some 1/2 inch copper. Flared it and polished it. Looks like a velocity stack to me. I should have one for 2 inch next week. I'll need to braze some filter medium in the neck and make a grommet for the mounts,but it looks pretty straight forward to me.
Ok.. new pics (still not very good. I used an iso for low light that made the pics really noisy) and if I can figure it out... video...
The seat.
and the bike....
how about the vid..
http://www.youtube.com/watch?v=3XopcRFs7kY
Canuck Plumber, where did you get your shock absorbers from? I've been looking around for some new ones for my CM400 and haven't come up with anything yet. Nice looking bike by the way. I can only hope that mine will look half as awesome as yours.
I bought them at Cycle City here in Calgary. The stock shocks were not long enough to give the back end the hike I wanted and they were not available any longer in a "clevis by clevis", so I bought the longest shocks I could get and changed the frame over to "eyelet by clevis". I imagine you will have the same problem if you're going to do the same thing. I think they cost around 80 for the pair. Thanks for the comps. I sure your bike will be wicked.
The electrical problem is just about finished so I should have it running by next week.
Thanks for the info. My CM has an eyelet by clevis setup so I don't have to worry about modifying the frame. Good luck with your electrical issues.
man. ive said it before, but i love your bike. maybe its the lack of gauges or just the 400 frame. anyway, good luck with the electrics.
Thanks. If I can get it up and running, I've been asked to put it the Calgary World of Wheels in Feb. Not sure if it's that kind of calibre but I might do it if only for shits n giggles.
Cheers n Beers
Ok. Back to the velocity stacks. I am still waiting for the 2 inch flare kit to arrive from out east, so in the mean time I'll document how far Ive come with building them.
First; the copper. I chose type "L" copper for its wall thickness and temper. I cut two pieces matching at four and a half inches long.
I've seen some guys run velocity stacks with no filter medium and that concerns me somewhat. I don't want something getting potentially sucked in as I'm driving down the road so I purchased some fine brass mesh to act as a filter medium.
I then used a piece of paper to make a template for the size of filter I wanted.To allow for a maximum amount of airflow with the brass mesh I formed it into a cone. I think it will look really cool once it's all fabricated too.
I cut out the mesh to match the template
I then cut tabs on the one edge of the cut out to interlock the cone and help keep it in place to solder it together.
Then, I carefully rolled the brass into shape and viola!
I'll jelly it into the pipe and solder it in place after the pipe has been flared. Then a good sand and polish and it will be ready to mount to the bike.
I'm told my flare tool will arrive next week.
Stay tuned.
:P
