Another new guy here with overcharging problems
Hootiebob
Built not bought
I'm new here and in need of some help. I'm having some overcharging problems with my 6v 1980 CB125s. At idle I get 19-20 volts and they go up with the throttle. The bike is bone stock other than a battery eliminator. I get the same reading with a battery as well. I put on a new rectifier and nothing changed. All systems check good according to my clymer manual. Any help would be greatly appreciated as I have been fighting this issue for a month now.
Only the rectifier, I don't think they used regulators on the 6 volt system but I could be wrong. According to my manual I should get around 7 volts without a battery at all, at the terminals. Is my stator bad, I've never had one overcharging. Thanks for the reply.
I thought I would add a few pictures for yall to check out. She is ready to ride other than the overcharging problem. I'm getting antsy to ride her so I'll take any input I can get. Thanks in advance. What do yall think of my little thumper?
In the case of the 6v Hondas the battery is what regulates the power after the rectifier. On a stock bike, if you run the bike without the battery, often the lights will pop.
What does your 'battery eliminator' consist of? A capacitor? This is where your issue will be, almost surely.
I have never used one of these, but this may work for you. http://www.ebay.com/itm/12V-to-6V-DC-DC-Buck-Converter-Power-Supply-Voltage-Regulator-LW-/171837785710
I realize that the spec'd input is 12v DC and that you are running 19+v, but chances are the regulator can handle more input voltage. If not you're out 4 bucks and we will have confirmed or eliminated this option for more than just your own bike.
I like to watch people pay for and try stuff that I might learn from, :-) .
Thanks for the input. I saw that regulator the other day and was thinking of trying it out.i have a bat-pack battery eliminator on the bike now. It's just a capacitor in a fancy case. I don't want a battery on this bike if I can get by without it somehow and not blow all the bulbs again. I'm going on eBay now and order that regulator. Hopefully it works out, I'll let you guys know what happens. I've also thought of putting a cb350 stator in there with a good rectifier regulator. Might as well go 12 volt since all the bulbs are bad anyway. How does the 12 volt system work with a battery eliminator? Thanks for help!!
Poorly. These bikes don't NEED a battery necessarily, but it solves a lit of headaches. Why are you dead set on not running one? There are some super compact units that work really well.
I'm trying to knock the ugly off of it and lose a few pounds. I've got a lot of time blasting and powder coating everything, I just don't want a battery to leak out on it. Plus I have done away with the stock battery box/air cleaner. What options do you suggest for a battery?
Honestly if you are going to go back to running a battery, the orig battery is the most reasonable option. The antigravity 6 volt is not much smaller, it costs $200, and your charging system wont like it.
Using strictly a capacitor for regulation is going to produce varied results. I think the ebay regulator is a good option, if for nothing else than cheap research.
As a side note, its coming from china so expect a week minimum. I will say that shipping from overseas has gotten considerably faster in the last couple years, imho.
Did you leave the battery mounts intact? Building a better lookin batt box might be another option, possibly even as a stand in until the reg. shows up.
Your bike is rad. I like the dirt tires a lot. Next cb/cl 100/125 that comes my way will be getting this 199cc 9.2:1 electric start 5 speed with 12 volt charging. Big Block power!
Looking at your pics... There are numerous options for discreetly mounting a small 6v battery. There are some cheap and tiny (about the size of a pack of smokes) 6v batteries available.
Thanks for all the help!!! I'm gonna get on eBay and order some more parts. At some point we'll get this thing figured out. I can't be the only one around eliminating the battery on a small six volt Honda. I don't mind being the ginniepig,hopefully we can all gain some knowledge from this. Thanks for the help I'll keep you posted.
Your question raises questions, lol. I'll explain.
If you are refering to the engine, it is neither. It is a 2012 Zongshen dirt/enduro bike engine. These engines are neat. The bottom end is a direct bolt in to any honda that uses the pattern of the small displacement upright singles that are in LOTS of bikes. The top end is visually very similar to a Yamaha TW200 topend with relation to the big square cylinder and head. I had it installed in the trike in my avatar pic until replacing it with a 233cc pushrod engine with reverse. Anyone that doubts the reliability of the chinese engines might be shocked to know that my TaoTao powered 200x took me through 1200 miles of desert and mountain highways from phoenix to central nebraska in 5 days with no mechanical failure.
Now, if you are refering to the old ATC under my workbench in the background, yep, that's an old atc. It lived most of it's life as a U-Haul rental:)
I see the reasons for wanting to go batteryless, number one probably being 'just because dude', but if it fights you much more, just get the tiny battery that VonYinzer posted. There IS a point where it's like "ok, that's why Mr. Honda did that".
But let's just hotrod till that happens haha...Stock Sucks!!!
I don't doubt the reliability of the Chinese engines, they let Honda and Yamaha do all the r&d and just copy it. It would be nice to have 12 volt, electric start and of course more power!!
I found a 6 volt rectifier regulator on eBay. It's for the gy6 engines going in older 6v Hondas. I ordered it and a small sla battery. I'm going to try the new regulator with the battery eliminator first. Cross your fingers and toes, hopefully this will calm her down so I can put some new bulbs in and ride.
A rental atc,wow. I wonder how many people it has crippled in its life. My little atc70.... Well 88 has hurt all my buddies around here. Maybe it's the twist throttle, high comp. bore kit or they just can't ride an atc.
Actually that is a common misconception. I have yet to find a copy of a Honda engine. The only thing that is the same about these engines is the mounting pattern. Yes, they are based on proven designs, but so are the big 4's engines. Yammi and Kawi certainly draw from Honda's experience and vice versa because it it would be a huge risk to defer from the technology that has already been proven, accepted by the target market, and can be built upon.
China produces engines for every single one of the major manufacturers. Almost every kids sized ATV for every brand is built in and shipped from china.
The bore, stroke, and compression ratios of each of the Chinese engines I own are not seen in the Honda engines they can replace. One is a 4 speed manual with reverse, pushrod engine. The Chinese manufacturers have to do r and d on their engines just like everyone else, because they are the ones that designed it. Lifan is a huge company.
If the trike was rented by responsible, aware, properly geared riders then it crippled none. My question is how many different people had a blast exploring on it in a time when no other vehicle would take you to places an ATC would go.
My trikes all have twist throttles. My wicked x will lay solid black lines on the pavement through 2nd, cruises down the highway at 60,and was regularly ridden through the very hectic streets of Phoenix, and it has never been close to wrecked. In fact in all the years riding three wheelers I have never crashed one. Know your machine and ride within your limits.
On the over hand, I've crashed quads and bikes bad. Quads kill people daily. Last time I rode one an ambulance showed up. I find it funny how people still refer to atc's as killers, then hop onto their kfx700 or 450r and pretend like its safer.
I don't know much about the gy6 platform so I don't have much input on the regulator you chose at the moment. Kudos for just getting the reasonably suspect, affordable parts and just going for it. That's how its done.
