(Another) NX Dominator build
edward.teller
Hi Folks, I'm Chris from Austria's capital Vienna.
After building a nice little GN250 based Tracker I realized that with 186cm a GN's a little bit too small for me.
As regulations here in Austria are a pita, I was looking for a donor bike with a frame that already is short enough. With the NX's exhaust not sticking out like hell the choice was an easy one and I got my hands on a bike with a mileage of just under 11000.
I instantly started to rip off all the ugly bodywork and electrics and searched for a tank. I decided to go with a 76' CB360 tank because i wanted a straight line on the bottom to go with the rear frame.
Because of regulations there's no way to cut and alter the rearend, so I had to figure out another line. I decided to lift the rear of the tank until it follows the line of the frame and use the extra room under the tank for cable stuff.
tbc
Who is going to know if you lift the subframe in the front and paint it nicely? 8) I believe in all EU countries modifying frames is not allowed unless you get a written permit, yet everybody does it.
I like the tank too, but I wonder if you're losing 1/3 the capacity with the petcock raised so much.
Ok, after another day in the garage it looks like this:
Unfortunately the CB360 petcock leaks so I gotta find a replacement gasket (the rubber one behind the lever with the holes in it).
The current seat is not final but I want to get this thins on the road asap. Over the winter months I'll have a pro fabricating a nice leather seat.
Yeah, the petcock sitting so high is a concern. When riding the bike the suspension is compressed a fair amount resulting in a much flatter angle. We'll see... maybe I have to relocate the petcock or find another solution for it.
Reg. frame mod: There's no way you'll pass inspection. Folks here compare the bike to the official picture in the registration papers. They even take out a measuring tape if in doubt! Seriously!
In that case, good luck :) Nice job btw, with so little time.
Ok, we moved into an old house that required some renovation so no time to wrench on my bike during winter. Over the course of the last 4 months however I managed to get the bike done.
Cleaning the front end
Suspension parts
Painting the frame, engine and other components with a black chassis paint with Owatrol oil.
New 17" front wheel and Conti rubber
Painted wheel
Unfortunately Austrian regulations prohibit open air filters, so the airbox had to be reused. Cutoff the snorkel however
Fork lowered internally using spacers.
New bearing
Removed the paint from the gas tank.
Now electrics. I decided to create a new cable assy from scratch.
Bought a new electronic CDI and an electronic box for indicators, fuses and stuff (similar to the m-box).
First rear end version with a short fender
I later decided to drop the fender, shorten the frame a bit, relocate the Motogadget indicators and use a new license plate.
The flat angle of the license plate however is illegal in Austria, so I guess I've to find a solution for that. Maybe something adjustable? Don't know yet.
Liking the overall look, tank/seat alignment is cool, forward seat cushioning is a must I reckon haha......are you fitting a front guard?
I like the rear fender placing and size, goes very well with the bike, it gives the bike a rugged-dirt-bike-like look. I also think gets you a more balanced look on the overall bike
Sent from my GT-I9300 using Tapatalk
Ok, the other day I got my hands on a rare piece of metal: a Tarozzi fork brace. Quite an upgrade to the fork's stability while the front fender is adding some comfort.
