Another tire question
Rimmy
Hello DTTers,
I have a tire question for ya. When I'm looking at some websites they'll have tires in the same make and model but they're listed as front and rear. Can I put what they call a rear tire on the front if it fits the rim? Not all of the companies make front tires that fit my front rim...
Any and all help will be much appreciated,
-jordan
I wondered the same thing, but no. A rear tire is made with the tread and the underlying layers laid down in order to be under tension while accelerating. A front tire is designed to have forces applied in a "reverse" direction (braking). Rear tire gives grip when moving forward, front tire gives grip when slowing down. Best advice, mix and match tires, find another rim in a more popular size, or pick a different set of tires. Those are the only "safe" alternatives. Good luck.
Thanks my-79-750-k. I had no idea they were designed like that, though it really makes sense. Now I just have to find either a manufacturer that makes them in my sizes or mix and match like you said.
-jordan
Some rears can be mounted on front in a reverse rotation and a quick email or phone call to the manufacturer will get you the answer. Not all tires are built the same and only some have the problem mentioned above some will only cause an issue being mounted on front if you are in rain as the tread is designed to shed water different on a front tire than a rear. You just have to ask the peeps who make the tire. I have Avons, and they make some universal tires that mount either fron t or rear and you have to mount them in reverse of each other. I have a front specific and the guy who mounted it at the shop, put it on backwards, before I went and asked them to fix it I called Avon and asked what would happen if I just left it. There was no danger in leaving it due to braking forces etc. but they told me it would not work right for rain dispersement so I went and made the shop turn it around. I ride in the rain a lot. It was just a tread pattern thing.
Cheers,
If you mount a rear on the front just reverse the rotation arrow.
Saying that, are you fitting an oversize tyre to stock rim?
That's not a good idea.
I plan on putting stock sizes on, but the problem is they are in that old inch-rim format, unlike the modern tires. I just got the bike yesterday and I forgot to look at the actual tires, but from what I've gathered an '84 CB125S has 2.75-18 front and 3.00-18 rear. Also, I still need to get the proper repair manual for it. They changed the bike over in my year from 6V to 12V and I can't find the manual.
Anyhow, I'm looking for some dual-sport type tires, and most don't come in these sizes front and rear. Michelin makes some cheap moped tires that will fit the bike, and might work with what I'm trying to achieve. It's actually probably a good thing they're cheap since I plan on making it into a cheaper version of the Deus Bali CB100 to ride around in this season, but then next winter I'm gonna tear it apart and cafe the hell out of it, which means I'll need road-oriented tires.
Tyres for low power bikes are rarely directional, even if marked front/rear.
On 400lb 180 mph bike I would be concerned but on a CB100........................................................?
Bridgestone Batlax Bt-45's
Bridgestone Spitfires S11
Avon AM-26 road riders
Continental Conti-go
Kenda K657 challengers
Anyways those seem to be the popular ones around here, ive probably forgot some but its a good place to start..
I agree with PJ on this one. Just get the water dispersion correct. You won't be shredding the rear tire up any way.
And check out JCWhitney.com for smaller tires too. Dennis Kirk carries a great selection, but JCW has some odd ball small sizes.
